Magical Skew - Page 4 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 09-16-2016, 09:41 AM   #31 (permalink)
Magicbob's Avatar
Photos: 6
Default
the shank on the Magical Skew is Hex shaped not square
__________________
Inventor of the Magical Skew
M
idwest Penturners Gathering 2019
Date, Time & Location - TBA
Go here: Facebook Page to read about past MPGs
Magicbob is offline   Reply With Quote Top
Old 05-11-2018, 11:16 AM   #32 (permalink)
Photos: 1
Default
I will look into those.
It seems like I am hearing that either the square or the round head can be used start to finish?
DennisM is offline   Reply With Quote Top
Old 05-11-2018, 12:40 PM   #33 (permalink)
mecompco's Avatar
Photos: 10
Default
I've been using mine for over a year now, haven't touched my HSS tools since. It really is a pen turning machine, at least for me. The hefty metal handle is top quality--it's a really beefy tool.
I alternate between cutting and scraping as I see fit. With a reasonably sharp cutter I can easily leave a finish on plastic blanks that require little to no sanding.
I'm sure a tool with a round shaft could also be used this way, but as Bob says, the hex shaft gives you an easily indexed and repeatable angle. If you want to scrape, simply hold the tool flat to the work.
I highly recommend the R2 cutter--it is what I use start to finish, but it will also take square and round cutters.
Regards,
Michael
__________________
Michael
Fairfield, Maine
mecompco is online now   Reply With Quote Top
Advertisement
Old 12-16-2018, 05:57 PM   #34 (permalink)
chartle's Avatar
Photos: 0
Default
Not sure if I should tack on to this thread or start another, but Bob I finally got to use the Magical Skew I won at MPG (My hobby time is limited). But just started to use it on some Xmas items.
Is there a reason the end of the bar is squared off? Its like if I angle the bar just a little over 90 degrees either way the corner hits the blank.
Is it a way to sort of force us to make sure the tool is almost 100% square to the cut?
Just wondering before I take a grinder to the corners. :)
__________________
Cliff
chartle is offline   Reply With Quote Top
Old 12-16-2018, 07:38 PM   #35 (permalink)
Photos: 0
Default Magic Skews on sale
I just ordered the triple combo, but was able to customize my bar choices. Use code Christmas18 to get 10% off. (There was an IAP thread last week announcing this)
CaptainJane is offline   Reply With Quote Top
Old 12-16-2018, 09:31 PM   #36 (permalink)
Magicbob's Avatar
Photos: 6
Default
Cliff,
The tool was originally designed using and 18mm round cutter. But when we got it in production we could not find the 18mm rounds so we used 16mm.
Feel free to grind as you see fit, it is yours.
I have modified one myself.
BTW, we have 18mm rounds now.
__________________
M
Old 12-17-2018, 10:05 AM   #37 (permalink)
chartle's Avatar
Photos: 0
Default
Quote:
Originally Posted by Magicbob View Post
Cliff,
Ok just making sure grinding the end wouldn't let any magic out.
__________________
Cliff
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
