Magical Skew - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 08-12-2016, 09:42 AM   #11 (permalink)
walshjp17's Avatar
Photos: 5
Default
I bought mine at MAPG and have not regretted it. It is my go-to tool for pens. It makes quick work of alumilite, PR and Corian. No more chip outs.
__________________
ZipIt!
John
USN (Ret)
Carolina Piedmont Chapter
walshjp17 is offline   Reply With Quote Top
Old 08-12-2016, 09:51 AM   #12 (permalink)
BRobbins629's Avatar
Photos: 49
Default
Won mine at the last bash. Works fine as advertised. I've even turned metal (mostly nickle silver) with it. My only complaints are that I wish the handle was longer and that a square cutter (no radius) was available. I know its designed mostly for pens, but for me, I would like it at least 12" instead of about 6" handle. The no radius cutter is needed to make 90 degree tenons. Still a good tool and a nice addition to my set.
__________________
Bruce
BRobbins629 is offline   Reply With Quote Top
Old 08-12-2016, 11:29 AM   #13 (permalink)
ExcaliburCraftworks's Avatar
Photos: 1
Default
We sell (and use) The Magic Skew at the Classic Nib - It does all it is advertised to do. Regarding the radius versus square cutter mentioned by Bruce - While the tool comes with a 15MM radius cutter please be aware that any 18MM square cutter will fit the handle. Also when I spoke to Bob at MAPG he said development is already in the works to make the tool handle longer. I have large hands and the current handle is a little short for me.
__________________
The Classic Nib - Niels and Debbie Mathiasen - Your source for Bock nibs and other fine pen making supplies http://www.classicnib.com
ExcaliburCraftworks is offline   Reply With Quote Top
Advertisement
Old 08-12-2016, 01:21 PM   #14 (permalink)
Photos: 0
Default Magic Skew
I bought a round carbide Magic Skew at the MPG and used it for about a month and then I ordered the Magic Skew with the square cutter. Both tools are fantastic and all I use presently. Worth the investment.
Gunnarkouper is offline   Reply With Quote Top
Old 08-12-2016, 03:41 PM   #15 (permalink)
Photos: 0
Default
Would this tool work on inlace acrylester?
jsmithmarcus is offline   Reply With Quote Top
Old 08-12-2016, 08:57 PM   #16 (permalink)
Photos: 0
Default
It's my guess it would be hard to get a smooth long taper or straight long cylinder with it. The advantage of a real skew is the you have the long bevel, and it acts like a hand plane. Nearly all carbide tools suffer the same disadvantage. They cut only as smoothly as you can move it along the tool rest.
low_48 is offline   Reply With Quote Top
Old 08-12-2016, 09:19 PM   #17 (permalink)
Photos: 1
Default
Thanks for all the testimonials. I guess this is next on my tool list.
MTViper is offline   Reply With Quote Top
Old 08-12-2016, 10:06 PM   #18 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Quote:
Thanks for asking this question. I have had trouble with anything but round shafts because so far square shafts act like scrappers. I have my perfect scraper and nothing else comes close (for me.) This one is square but presents the cutting blade at an angle. Seems intriguing.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is online now   Reply With Quote Top
Old 08-13-2016, 10:21 AM   #19 (permalink)
mark james's Avatar
Photos: 481
Default
I have been following this thread, and intentionally did not post for a bit.
Disclosure: Magicbob is a friend of mine, we both are active in the Ohio IAP Chapter and have gone together to the last two MPG's as well as the last MAPG.
I wanted a few others to give some opinions first.
However - I did a "pre-production" test-drive on the Magical Skew earlier this year. I was very impressed with the MS.
Hank: The tool shaft is not square riding on it's point - it rides on a flat, with the shaft on an angle.
Some pics will help:
Some of the tool; some with comparisons between the Easy Wood Round; and of my tool. Note: Magicbob did not have handles at this time, and as Bruce has indicated, you may want to go with a longer handle; I believe mine is about 14".
The three blanks are: #1 - Cherry, # 2 - Walnut, # 3 Oak
The tight grained Cherry had a noticeable advantage for the Magical Skew; the Walnut and Oak, less so, but still a cleaner cut.
These are my opinions only.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 08-13-2016, 10:50 AM   #20 (permalink)
mark james's Avatar
Photos: 481
Default
More pics I found:
__________________
Check out the
IAP Collection
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
