I do not remember who it was that talked about carbide inserts and the optimum angle. But I will ask as a general question if you happen to know. what the difference is in carbide cutters and different angles of the blades?? What would be the best use of each or is there a chart somewhere??? Where are you currently getting your inserts from and are you satisfied or are you looking for more??? I tried at one time to get a read on inserts designed especially for metals but could not get enough info that I understood to make educated buy. Thanks for your time.
