Lathe question for the machinist - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 07-09-2018, 10:51 PM   #1 (permalink)
triw51's Avatar
Photos: 0
Default Lathe question for the machinist
I recently acquired a used lathe and on the controls is a switch for long deceleration and short deceleration. I understand the difference in how fast the work slows down but would like to know the advantages and/or disadvantages of each. Can anyone enlighten me please?
Thanks William
__________________
ZIP IT Please
Western Creations Forge and Woodworking
Isaiah 58:6
triw51 is offline   Reply With Quote Top
Old 07-10-2018, 06:15 AM   #2 (permalink)
randyrls's Avatar
Photos: 68
Default
William; I've never had a lathe with this feature. Is this lathe a Variable Frequency Drive (VFD)? Metal lathe?
If turning / threading up to a shoulder, you want the lathe to stop RIGHT NOW. This is quite likely when making kit-less threaded pen sections. The common way around this is to turn as close as you can to the shoulder, then use a parting tool to plunge in and clean up the corner. This doesn't work for threads though.
However if your lathe has a threaded spindle nose on it, short decel may cause the chuck to unscrew. Some chucks will have set screws in the base of the chuck to prevent this.
The only likely reason for long deceleration would be if the work piece is fragile or has a very thin cross section at some point.
An intriguing question. I'll be interested in others comments.
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 07-10-2018, 11:17 AM   #3 (permalink)
triw51's Avatar
Photos: 0
Default
Randy it is a Oneway wood lathe and I don't know if it has a VFD or not. Thanks for the input appreciated
__________________
ZIP IT Please
Isaiah 58:6
Advertisement
Old 07-10-2018, 11:46 AM   #4 (permalink)
Photos: 1
Default
It is explained in the manuals. https://oneway.ca/manuals
Basically it is to protect the VFD. A heavy object stopped quickly heats up the braking resistors in the VFD. Slow deceleration keeps the braking resistor from getting too hot and shutting down the VFD. At least that is the conclusion I came to.
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is online now   Reply With Quote Top
Old 07-10-2018, 07:47 PM   #5 (permalink)
triw51's Avatar
Photos: 0
Default
Thank you Pete I missed that when I looked it up on line So apparently I do have a VFD.. Thank you for the information William
__________________
ZIP IT Please
Isaiah 58:6
Old 07-10-2018, 08:04 PM   #6 (permalink)
Photos: 1
Default
You’re welcome. All machines with electronic speed control will have a VFD and a 3 phase motor. The exception to that are the small lathes with DC motors. I am envious of your toy.
__________________
Pete
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
