rfreeouf
I am new to the forums and I am interested in turning pens. I basically have no turning tools at all so I am quite a noob when it comes to this stuff.
I have been looking for a midi lathe. I primarily want to turn small projects such as pens.
After hours of research I am still overwhelmed on making a decission. I think I have my choice narrowed down to the Jet Midi Lathe. I am just confused on the Regular version and the variable speed model. I understand with the regular version you will need to move the belt to adjust the speed. With th variable speed model still have to move the belt for the different speed range and then you can adjust the speed at that range.
What advantage does the variable speed model have over the regular version if you still have to adjust the belt for different speed ranges.
Is that speed feature worth it for a $100 extra dollars.
Should I be looking at a different lathe to start out?
Any help would be greatly appreciated.
