Thanks for the replies. I printed out a copy of the conversion chart. I actually printed out a second copy that I'm going to give to the people at the ACE up the street. I had gone there to ask them, before I posted here. They had no metric bits and the best they could do was to pull out one of those things that has holes in it so you can see where a bit fits, and then they tried putting various bits through the holes that were listed on that scale as one slightly larger than 7 mm and one slightly smaller, doing this all with the plastic still covering the thingy with the holes and the drill bits they were putting into it, so obviously there was quite a bit of plastic in the equation too! I am curious Frank/Eagle, what is the advantage of using CA glue inside the blank Which CA glue do you use, and when you say you ream it smooth, what do you use to do that? Is that in addition to people referring to sanding the outside of the brass tubes? And while I'm on a role of questions, what is the reason for breathing into the tube before gluing, as I saw mentioned somewhere?
I think I've about reached my allottment of questions for today! Thanks for all of your help!
