Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Reply
Old 02-04-2012, 11:15 AM   #1 (permalink)
Photos: 0
Default Interesting small table saw by Fred Brinks
I was browsing the web the other day and happened upon this YouTube video about a small table saw built by a professional model ship builder - Fred Brinks. Very cool saw! It uses 4" saw blades (same as the Byrnes table saw), but it goes beyond what the Byrnes saw offers - a sliding table, a very nice adjustable miter guage, and a robust DRO fence. The table size looks a bit bigger too. This is his prototype model, and he plans to introduce it to the market next month (March).
Most Accurate Small Table Saw in the World by Fred Brinks - YouTube
Sure, it's not the saw to get if you want to cut large stock. But if you're cutting small stock, it sure is a sweet looking machine.
__________________
John
jdmyers4 is offline   Reply With Quote Top
Old 02-04-2012, 11:28 AM   #2 (permalink)
bluwolf's Avatar
Photos: 1
Default
Looks like a nice piece of work. Maybe I'm being picky (or wrong) but the belt from the motor to the arbor looks terribly misaligned. I hope it can be adjusted. Other than that pretty impressive. I'm sure it won't be cheap though.
bluwolf is offline   Reply With Quote Top
Old 02-04-2012, 11:53 AM   #3 (permalink)
Akula's Avatar
Photos: 0
Default
seems like it needs more (LOL)
ok, looks just like a lot of overkill, pieces will hit the blade (very bad) and will be expensive...I'm positive someone will have a good use for it but not me. Just adding as much as possible to something don't always make it better.
Congrats to him on building something (adding on) for his needs.
The best thing I have seen for a table saw is the Stopsaw.
__________________
Stay away from the darker side, and if you start to go astray, let the force be your guide.
Akula is offline   Reply With Quote Top
Old 02-04-2012, 12:05 PM   #4 (permalink)
skiprat's Avatar
Photos: 156
Default
Looks very snazzy. I wish he would answer the question about the fence clearing the blade though.
Any machine that can be adjusted can only be as accurate as the setting made to it, so I'm not convinced it can claim to be the most accurate saw in the world.
__________________
skiprat is offline   Reply With Quote Top
Old 02-04-2012, 12:23 PM   #5 (permalink)
SDB777's Avatar
Photos: 0
Default
But does it cut anything....I never saw it run. Or did I blink and miss it?
Scott
__________________
No cheap blanks, just the cheapest blank prices!
Just added Sweetgum and some new stamp blanks!
Central Arkansas IAP Chapter Member
SDB777 is offline   Reply With Quote Top
Old 02-04-2012, 01:43 PM   #6 (permalink)
PTsideshow's Avatar
Photos: 0
Default
Problem with the small belt driven saws is the motors are generally under powered and the belts slip and pop off. I have had a 4 inch Dremel since the mid seventies. It is what it is a very slow feed speed saw for small items.
I used it for ripping red oak to make some small molding for the stairs in the house. And at times it wood pop the belt even cutting 3/8" x1/4" red oak. It isn't for production work.
That being said. Even the direct drive small saws under 6" will stall very easy.
The HF one has that problem you have to feed the wood in very slowly. Yes it will cut 3/4" blank woods. But wood better be used for smaller thinner pieces for segmenting etc.
Proxon has a small table saw, and Micro mark has thier version of a 4"
here is their page
I have been looking for a saw that you can use for model and small work.
Since table saws under 10" are hard to find, I considering to use my cheap contractor saw with a 1/4" sheet of ply on the top run the blade up through it for a zero clearance slot and have it just shy of the 3/4" so the rip fence will work for set up.
Or maybe make up a sliding table jig with clamping fence and guard that will use both of the miter slots.
I just picked up a Freud thin kerf 10" blade today a multi tooth combo blade for a glass smooth finish.
I have come to the conclusion that it will be the best and easiest solution.
PTsideshow is offline   Reply With Quote Top
Old 02-05-2012, 10:03 AM   #7 (permalink)
nava1uni's Avatar
Photos: 18
Default
here is their page
You should look at Byrnes saw. Several members on here have one and it has an excellent reputation for it's quality and it's ability to cut.
__________________
Cindy
San Francisco, CA
"All the strength you need to achieve anything is within you"
nava1uni is offline   Reply With Quote Top
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
