Homemade closed-end pen mandrel - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 04-16-2018, 07:24 PM   #11 (permalink)
Photos: 0
Default
Turn an extra long blank round to 3/4" diameter. Insert in collet chuck, finish turning to diameter you want the pen to be, drill to depth needed and glue in brass tube. At this point you can part off the extra length that is in the collet. No special mandrel needed.
dogcatcher is offline   Reply With Quote Top
Old 04-16-2018, 08:31 PM   #12 (permalink)
Photos: 38
Default
If you don't want to make a mandrel how about the closed end mandrel from Penn State?
__________________
Regards,
Mike
Penultimate is offline   Reply With Quote Top
Old 04-17-2018, 06:09 AM   #13 (permalink)
geoffholden's Avatar
Photos: 3
Default
I had another thought about how to do a closed end part without a specific mandrel. I haven't tried it on a pen yet, but it was successful on making a closed end keyring out of a cutoff. I glued the tube in, but left an inch protruding. I then gripped the tube in a collet chuck and turned the piece. Then I only had to part off the brass tube and it was done.
Sent from my Nexus 5X using Tapatalk
__________________
Geoff Holden
Instagram: geoff.holden
geoffholden is offline   Reply With Quote Top
Advertisement
Old 04-17-2018, 06:26 AM   #14 (permalink)
randyrls's Avatar
Photos: 68
Default
Quote:
Originally Posted by MiteyF View Post
Virgil, you've got a dead link.
This one will work for Don's (its_virgil) web site. Wooden Pens: Buy Handmade unique custom rattlesnake wood pens gifts fountain pen exotic wood from Red River Pens
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 04-17-2018, 07:04 AM   #15 (permalink)
its_virgil's Avatar
Photos: 73
Default
Thanks Randy. Here it is again: Wooden Pens: Buy Handmade unique custom rattlesnake wood pens gifts fountain pen exotic wood from Red River Pens
Do a good turn daily!
Don
__________________
Don Ward aka its_virgil
Wichita Falls, Texas
www.RedRiverPens.com
www.RedRiverPens.com/articles.htm (pen stuff I've written)
its_virgil is offline   Reply With Quote Top
Old 04-17-2018, 11:16 AM   #16 (permalink)
Rick_G's Avatar
Photos: 30
Default
I just use the transfer punch set. If I don't have one of the correct size I just take the next size larger and either turn it down or sand it down to the correct size and make a pin mandrel. Work on the end opposite the point so it's still usable as a transfer punch. Takes a while but cheaper than buying a mandrel for each tube size.
__________________
Rick
I support
The Pens for Canadian Peackeepers Project
http://www.undergroundwoodworking.ca
Rick_G is offline   Reply With Quote Top
Old 04-17-2018, 02:23 PM   #17 (permalink)
Photos: 0
Default
Geoff, that's not a half bad idea. I'd be a little concerned with the strength of the brass tube, but it certainly sounds doable with a bit of finesse, or perhaps another bit of wood, drilled to accept the brass tube, and turned down to add strength.
I really like the idea from the link posted about using a regular mandrel, a single bushing and some carefully placed holes too. Seeing as it doesn't require any new tooling whatsoever, I think I'll give that a go first. Now, which of my on-hand kits do I risk?
This is a lovely thread with some great ideas.
MiteyF is offline   Reply With Quote Top
Old 04-17-2018, 02:31 PM   #18 (permalink)
Photos: 3
Default
I tried it out today on a crochet hook handle, with a minor modification and it worked great. I held the blank as I described long enough to turn a tenon on the other end, then I held that end I the collet chuck for 90% of the work. When the bulk of it was done and finished, I flipped it around again and put the protruding tube in the collet to part off and finish the end.
__________________
Geoff Holden
Old 04-17-2018, 02:33 PM   #19 (permalink)
Photos: 0
Default
Simple answers are almost always the best. This sounds like another good method. And you can turn the tenon to whatever diameter collet you're looking to use.
Old 04-17-2018, 04:49 PM   #20 (permalink)
Photos: 0
Default
Yes, simple is good. As long as you have a piece of tube on hand that is the correct dims and longer than needed it should work well.
PatrickR is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
