Hodge Podge collection of home made tools
Drums, PA, USA.
These tools ain't pretty and I am not an expert at making tools, but hey, they work.
All the tools use copper piping for ferrels (sp). Expoy was used to hold the blades in place and they are 2"-3" deep into the handles. The round stock was purchased at a local big box store. The HSS bits where purchased at Enco. The scraper bits on tools 4 & 5 can be purchased at CSUSA.
L to R
1&2) These are the first two tools I made. They are parting tools using sawzall blades and 1" wooden dowels I had in the shop. The longer blade is 1/16" thick and the shorter blade is 1/32" thick. They cut with the long tip down. They work really well.
3) This tool uses a 1/4" square stock with a 3/16" HSS bit welded on at about a 45 degree angle. This has a dimpled walnut handle.This is used for small hollow forms to remove wood under the lip.
4) This tool uses a 1/2" round stock with the end ground at about a 15 degree angle and tapped to hold a store bought tip.The handle is really to light for this tool, I'm waiting for some hickory to dry so I can remake this handle.
5) This tool uses a 5/16" round stock. The end is ground down at about 15 dregees and tapped to hold a store bought tip. The bar is to light and only works with a small hollow forms. I plan on making another with some thicker bar stock. The handle is from my Kelton Coring System.
6) This tool is my favorite skew made from 1/4" drill rod and set into a bubinga handle.
7) This tool is made from 3/8" drill rod. I figured since I love the 1/4" skew I would love a slightly bigger one all the more. Wrong! One day I'm going to regrind this into a three point tool.
8&9) This two are from Don Pencil
Dario
Austin, TX, USA.
NICE!!! I like them [:)]
I am planning on playing with some steel too and attempt making some tools. There are so many pics on catalogs to help me get started. [;)][:D] Enco sells really cheap HSS cutting stock and I do believe they have the best prices and selection.
This means, I may start making bowls again [;)]
Thanks for sharing!
tipusnr
Reynoldsburg, OH, USA.
Nice collection. I am really envious of those of you with metalworking skills and the willingness to improvise. Trying this stuff scares the ....HECK....out of me!!
Drums, PA, USA.
Bill
there is really very little metal working skill involved. My method is Neanderthal at best. The fanciest is drill a hole and run a tap through. I use a grinding wheel and eyeball the angle for tool #4 and #5.
Dan
Glad to hear that. Since it's a small investment it's no big deal to remake a tool that doesn't perform the way you want.
Steve
Do you know where I can get some carbide tips?
dfurlano
Avondale, PA
Harbor freight I thought had some carbide blanks that are for metal lathes. I may be wrong and they are only HHS I'll look next time I am in the store.
Borg_B_Borg
Castro Valley, CA, USA.
I was referring to the indexable carbide inserts. Enco has a free shipping deal for orders more than $50 until the end of March. Code is NRFB6. Too bad they charge me sales tax, even though they are in NV and I am in CA.
Steve
Originally posted by Ron in Drums PA
Steve
Drums, PA, USA.
Originally posted by Borg_B_Borg
<br />I was referring to the indexable carbide inserts. Enco has a free shipping deal for orders more than $50 until the end of March. Code is NRFB6. Too bad they charge me sales tax, even though they are in NV and I am in CA.
Steve
Steve
I was looking at those tips from Enco (pg 60 of the 2006 catalog). Not having a machinist background I really have no clue if these would work.
Maybe you can help me.
The sizes are not listed. I need an insert that is 0.75" to 1" round or square and .125" to .187" thick. I can alway grind them to the right shape.
I also need a .125 to .187 hole, I don't think my HSS drill bits will cut carbide. How can I drill them?
Thanks Steve
Dario
Austin, TX, USA.
I have some carbide tips for metal lathe...even the new ones feel "dull" and I doubt you can sharpen it easily even with diamond hone. These have the carbide tips, welded (or imbedded) on a 1/2" sq steel shaft (if memory serves me right)....maybe those will work?
Paul in OKC
Oklahoma City, OK, USA.
Carbide tools like the ones on the square shanks are generally useless out of the box. It takes a special wheel (green) to grind them and you can not use any regular drills or tools to cut them. That said, there are some round and square ones that have a pretty good edge on them new. The round ones are inserts, the square ones are usually 'seats' that go under another incert, but they are carbide and have a good edge on them. HTH
Dario
Austin, TX, USA.
Paul,
Are those inserts good? I also have some of them...some are square, triangular, diamond shaped and some are thin long ones. Some of them have hole in the middle and others are solid. The tip are also varied, some are pointed othera are a bit rounded. Not sure if I am making any sense.
I'll try to dig them out (if I can still find them [:D]) and post a pic tonight.
leehljp
Member Liaison
Tunica, Mississippi,
I have been planning my own too. I haven't had the time but the planning is even down to the ferrells being copper too! Copper looks great with cherry handles. You have given me some great ideas. Thanks!
Drums, PA, USA.
Originally posted by Paul in OKC
<br />Carbide tools like the ones on the square shanks are generally useless out of the box. It takes a special wheel (green) to grind them and you can not use any regular drills or tools to cut them. That said, there are some round and square ones that have a pretty good edge on them new. The round ones are inserts, the square ones are usually 'seats' that go under another incert, but they are carbide and have a good edge on them. HTH
So I can't grind them on my white wheel, bummer!
Paul, I've been looking for round ones but havn't found any in HSS or Carbide expect for the overpriced ones in the woodworking catalogs. Do you have a scource?
Borg_B_Borg
For use with leveling crushed stone inlays (the kind that BB sells), the carbide edge doesn't need to be very sharp. It definitely doesn't have to be sharp enough to shave wood. In fact my carbide tools that I use for stone inlays seem dull compared to my wood turning tools and they work just fine for this purpose. I think the carbide inserts or the metal lathe bits should both work fine for leveling crushed stone inlays, without modification, although I have to qualify by saying I haven't personally tried using either. I bought my carbide tools from Charlie Glynn who's no longer selling them.
Steve
Originally posted by Dario
<br />I have some carbide tips for metal lathe...even the new ones feel "dull" and I doubt you can sharpen it easily even with diamond hone. These have the carbide tips, welded (or imbedded) on a 1/2" sq steel shaft (if memory serves me right)....maybe those will work?
Paul in OKC
[/quote]
[/quote]
Nope, they will shape your wheel[:D] I'm not sure where the round ones I have came from. I have seen some similar in the MSC catalog (mscdirect.com) and maybe the Enco book.
TomServo
Grand Forks, ND, USA.
The best carbide to use for cutting wood and such is the relieved type - the little triangular or square inserts with a groove next to the edge. It provides a sharper angle of cut and a much nicer surface.
There's no reason to buy a holder for them, you could make your own the same as for scrapers..
An insert such as: http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=422-2922&PMPXNO=7908859
It's a 1/2" carbide insert, with a 3/64" rounded corner, TiN coated,
3/8" is much cheaper - 5.47
http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=891-6961&PMPXNO=3906430
same 3/64" radius, TiN coated
to read the insert sizes, it goes like this:
xyz (323)
x = size overall in 8ths of an inch
y = thickness in 16ths
z = size of radius in 64ths
as far as honing carbide goes, diamonds are the answer.. carbide is around 80 Rc hardness.. HSS is like 60-63
alamocdc
San Antonio, Texas, USA.
Nice looking handmandes, Ron. So far my only handmade turning tool is a 3/64" parting tool that I made from a butter knife (6 for $1 at Wallyworld), but it works great.
