Hocus Pocus!! lathe into drill press!! - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 12-14-2010, 01:19 PM   #1 (permalink)
Photos: 3
Default Hocus Pocus!! lathe into drill press!!
Has anyone tried engineering a vertical "bed" to replace the tailstock on your lathe thus turning it into a horizontal drill press?
If so I'd love to hear and or see ideas?
MatthewZS is offline   Reply With Quote Top
Old 12-14-2010, 01:27 PM   #2 (permalink)
underdog's Avatar
Photos: 0
Default
Whatcha trying to drill?
I've used a drill in the headstock, the tool rest to keep square stock from turning, and the tailstock to advance it.... Made plenty of handles this way.
__________________
Jim Underwood
....finding every way to screw up a pen, then inventing new ones...
underdog is offline   Reply With Quote Top
Old 12-14-2010, 03:07 PM   #3 (permalink)
rej19's Avatar
Photos: 9
Default
Sounds like a Shopsmith.
__________________
Ron in Indy
rej19 is offline   Reply With Quote Top
Advertisement
Old 12-14-2010, 06:11 PM   #4 (permalink)
Photos: 3
Default
Not trying to drill anything specific. Pen blanks mostly, which I know I can do with a collet chuck or some other arrangement...... But I got thinking that if I could easily turn this into a horizontal drill press It might could fill ALL my drilling needs. I'm going to be operating in a tight space, so the more multi purpose I can make my tools, the better.
Old 12-15-2010, 12:28 PM   #5 (permalink)
BigguyZ's Avatar
Photos: 24
Default
Why not just use a faceplate with a piece of MDF on it? You could get a MT2 to an 8TPI 1" headstock adapter and then thread on the faceplate.
BigguyZ is offline   Reply With Quote Top
Old 12-18-2010, 10:08 PM   #6 (permalink)
Photos: 0
Default
What I started doing is cutting my blanks to size on the saw, chucking them up in the pin jaws and mounting a dead drill chuck, http://www.pennstateind.com/store/TM32KL.html
after I have figured out what is going to be used in what pen, say if Im making slimlines, I'll drill all my blanks Im going to use at the same time, usually takes less time to do this then marking the center and moving over to the drill press. After that I'll mix up some epoxy, glue the tubes in and then clean up my chips or go inside for a drink or corral the kids. Once the epoxy has set I'll put the blanks back in the lathe and use this to square the ends.
http://www.pennstateind.com/store/SPA2PAD.html
Usually about a 60-100 grit, I'm sure there are better ways but this is what works for me.
Verado is offline   Reply With Quote Top
Old 12-18-2010, 11:29 PM   #7 (permalink)
ldb2000's Avatar
Photos: 235
Default
He's not just talking about drilling pen blanks , but rather turning a lathe into a movable table drill press .
While the idea has some merits the engineering has several problems . What would you use for a rack/pinion to move the table/tailstock and would it be permanent or removable so you could easily convert either way ?
__________________
Butch
Kitless Fanatic
The simplest method is usually the best solution (Me )
Any fool can know , the point is to understand (Albert Einstein)
There are no mistakes....Only happy accidents (Bob Ross)
ldb2000 is offline   Reply With Quote Top
Old 12-18-2010, 11:35 PM   #8 (permalink)
KenV's Avatar
Photos: 0
Default
Of course you can do it -- Should function fairly well with two toolrests on the system. It will be ackward in many situations, but it can be done.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 12-19-2010, 07:05 AM   #9 (permalink)
randyrls's Avatar
Photos: 61
Default
Matthew; I would only add one caution; You will need a drawbar and a jacobs chuck with a threaded taper. This keeps the chuck safely in the headstock and mot chasing you around the shop!
__________________
Randy S.
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
I expect to pass through this world but once. Any good, therefore, that I can do or any kindness I can show to any fellow creature, let me do it now. Let me not defer or neglect it for I shall not pass this way again. -- Stephen Grellet
randyrls is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
