vtgaryw
I've seen several references to pressure pots leaking, even in a couple of the library files about building pressure pots. I cannot get a solid seal on my HF pressure pot. When I use it as a vacuum chamber, I have a gasketed piece of 3/4" plexi that seals just fine.
But when I use the lid that came with it under pressure, there's one section I cannot get to seal fully. There seems to be a slight "bump" on the top edge of the pot rim. Has anyone figured out a good way to gasket these lids to get a better seal?
Thanks,
Gary
Thanks,
Gary
