Hi, do you mean the lever that locks the tails stock back and forwards...?
If that is the case, is possibly because you have saw dust jamming the plate the tightens into the lathe bed, lack of lubrication can also be a problem.
You should be able to look underneath the tail stock assembly and use the air gun to blow any visible saw dust out, I would then spray a generous amount of oil into all that area, including the top rails on the bed around where the tail stock is jammed, leave it for a few minutes.
Grab a small piece of wood and a hammer, from the rear of the tails\ stock use the wood to push against the tail stock base and give it a wack towards to head-stock into the position you had it before it jammed, if one wack doesn't do it, try again a little harder and the tails stock should move, make sure the lever is positioned in the neutral position
It the tail stock loosens up, remove it from the lathe and give it a good clean then oil it and re-install, things should be working as new...!
Good luck
Cheers
George
