The interior should be 13.2 for the hole and the body tenon 13.9 For the interior threads, (drilled hole) take the diameter of the tap and subtract the pitch. (rule of thumb) 14-1=13. because the taps and dies dont cut 100 percent make it 13.2 or what ever is closest. You also need to keep in mind when measuring that wall thickness left after subtracting has to be divided in half. If you have a 15mm outside diameter and you tap it for 14 x 1 threads you have 1mm divided by two or .5mm wall thickness left(.019+/-)
