Drill press gloat!
Ligget
Bonnybridge, Scotland.
This is the drill press I just bought on Ebay. I am moving up from a 2" (if that) stroke. Fed up stopping during drilling to put a wooden block under pen vice to lift up work.
Brand New
Still In Box
Full Warranty
Heavy Duty Workshop Use Machine
Powerful 750 Watt Workshop Induction Motor
230 Volt 50Hz
Single Phase
Floor Standing Drill
Square Drilling Table
Drilling Table Can Tilt Up To 45 Degrees
No Volt Release Switch
12 Speeds
Drilling Speeds From 200RPM up to 2,600RPM
16mm Chuck Size
Can Take Up To 20mm Tapered Drill Bits
MT2 Morse Taper
Max Spindle Stroke Is 80mm
Max Distance Spindle to Table Is 730mm
Max Distance Spindle to Base Is 1220mm
Distance of Spindle To Coloumn Is 190mm
Overall Height Is 1630mm
Weight Is 90kg (very heavy, make sure someone helps you to take delivery of it)
Bought it for £155 plus £15 delivery. More room on my small bench and drill one half of a blank in one pull.
M
Mudder
Guest
Good on you buddy!
Nice to see you got wnat you want.
May it bring you many years of great service [:D]
Be sure to show us a pic when you get it all set up.
JimGo
North Wales, PA
Best of luck with it! I have my little 2 1/8" travel drill press, and have been eyeing up some of those bigger ones. It's on my list, once I start actually SELLING some pens!
Ligget
Thanks for the kind words, what I need now but can`t find it for sale anywhere, is the enthusiasm!!!!
I have searched high and low, on Ebay, done a Google search but nothing. LOL
(and yes I did look up the dictionary to get the spelling)[V]
