Drill Chuck ?
rjwolfe3
Mansfield, Ohio, USA.
I bought a drill chuck from AS and am using it for the first time in my Turncrafter Pro lathe. I noticed it seems to be too long. I have seen people shorten them in other posts. What is the easiest way to do this and about how much do people take off? Thanks
Nick
Lakewood, WA, USA.
Rob
I had the same problem on my General, I just used the grinder to shorten it. Go slowly and use a cup of water to cool, remove any "burs" before you try it for size so they will not score the MT.
Hope this helps
rherrell
Pilot Mountain, NC
Put it in the tailstock and then retract it until you can feel it bottom out. Now read the scale on the tailstock and add 1/4". Cut that much off the back and you're good to go. A hacksaw will work, just be sure to clean up the burrs with a file or a grinder.
rjwolfe3
Thank you all for the help. Rick, what scale on the tailstock? I will use a ruler, I think my lathe was too cheap to have that, lol. I just wanted to make sure I didn't screw it up. Thanks again.
