Drill bits.
eppen
Oakville Ontario
I would be interested in what style others use for drill bits and why.
I mostly have Brad point which I have used on wood and acrylics fairly successfully but was wondering about the benefits of other designs.
Anthony
JimB
West Henrietta, NY, USA.
I just use regular twist bits. I have the large set from Harbor Freight and a drill doctor to keep them sharp. Works for me. I've never tried any other types.
Woodchipper
Cleveland, TN
I got the drill bit set on sale at Woodcraft. It is a mix of regular point and brad point bits. Comes with a nice metal case to keep them organized. I have a bunch of bits that need to be sorted out and some tossed. My Rikon low speed grinder had a platform with an angled groove for bits. I have tried it and it does a good job.
Herb G
Southern Maryland
The problem with brad point bits is the fact they will ride along the wood grain & follow it right out the side of the blank.
They also have the tendency to split out the bottom of acrylic blanks as well.
I use regular point bits for most everything.
Monty
Group Buy Coordinator
Pearland, Texas, USA.
What Jim said. I've used brad points but they can leave chip out when exiting acrylic blanks.
Woodchipper
Cleveland, TN
I put a dimple in the wood with a sharpened nail to get the bit started. I do get some "drift" in wood blanks with the hole coming out off center but not enough to be concerned with as most wood is turned away. Good point - no pun intended. I use regular bits for acrylic.
thewishman
Reynoldsburg, Ohio, USA.
I bought the big Harbor Freight set and have used it for years. Replaced the most used bits with Norseman bits and now have replaced many of those with 135 degree cobalt bits:
https://www.mscdirect.com/product/details/43482470
The cobalt bits work very well and were purchased for drilling metals. They are overkill for acrylics and woods, but work so well that I use them when I can.
PenPal
Canberra, A.C.T., Australia.
Look into DeWalt Extreme 2 bits they have a drill point and flattish lands developed for cutting stainless steel by De Walt I have used them for twenty plus many years successfully. The 7mm drills give me hundreds sometimes many times that. I regard their cost as nominal only.
Peter.
PenPal
Pic of DeWalt Extreme 2 drill.
Peter.
PatrickR
Rural America
I remember seeing plastics specific bits that are shaped like a ream. Anyone use them?
Sent from my iPhone using Tapatalk
