dial indicator
jwoodwright
Anchorage, Alaska, USA.
Hey John,
All you need is a metal coat hangar. Cut the straight piece off at each end. Bend the straight piece into a Z. Depending on your table size, it will be 6inchs in the center and the other ends bent opposite.
Chuck the one end, the other touchs the table. as you turn the chuck by Hand (NO POWER) it should just touch the table in a circle. If it doesn't, adjust so it does. Finally, tighten the table as you are done...
rduncan
Albuquerque, NM, USA.
If you want to see this tip in video form along with one regarding setting drill depth accurately check out:
http://www.woodworkingathome.com/WaHM-OnLine/Xtras.htm
BTW if you get the DVD you can see Dick Sing each issue during his turning segment.
old folks
Mt Enterprise, Texas, USA.
Originally posted by rduncan
<br />If you want to see this tip in video form along with one regarding setting drill depth accurately check out:
Thank you Rick, actually being able to see how it is done really helped.
Randy_
Dallas suburb, Texas, USA.
".....Being married to a programmer is like having a cat. You talk to it but you're never really sure if it hears you, much less comprehends what you say...."
Travis: My cat understands me perfectly......she just ignores me.....unless I am saying something about food!![:D][:D]
