Delta parts problems? - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 02-17-2014, 10:06 AM   #11 (permalink)
plano_harry's Avatar
Photos: 5
Default
Eric, check this out:
Alternate Sources for Delta 46-715 Lathe Parts | Fine Woodworking Knots
Harry
plano_harry is offline   Reply With Quote Top
Old 02-17-2014, 11:01 AM   #12 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Quote:
Originally Posted by plano_harry View Post
Yes, I've seen that before. Unfortunately, the off-brand alternatives mentioned are for the drive pulley, not the headstock pulley - which is what I need.
If anybody knows of a Jet, Grizzly, or other headstock reeves pulley that will fit a type-2, I'd appreciate hearing about it.
Regards,
Eric
__________________
Eric Rasmussen
Rifle cartridges (bullet pen kits) for penturning available at:
http://www.bulletpenkits.com
Sylvanite is offline   Reply With Quote Top
Old 02-17-2014, 11:50 AM   #13 (permalink)
Photos: 4
Default
Eric, have a Delta 46-700 12” x 36” lathe and could never get reeve drive repaired. So took it to a local machine-welding shop and had them remove my reeves drive. Installed a pulley on headstock spindle, & belt, relocated the motor to a bracket that swiveled in and out. Moved the belt over spindle & motor pullies to change speeds. Total cost about $170. That lathe served me well for over ten years once modified.
could not re-install plastic headstock cover, and could not rotate the headstock anymore but that was okay with me.
Wildman is offline   Reply With Quote Top
Advertisement
Old 02-17-2014, 11:58 AM   #14 (permalink)
PenMan1's Avatar
Photos: 93
Default
I am just going to get my parts from Andy, since I know where they all are
It may cost me a little more...
Harry
A LITTLE more??????? Bahahahahaha! Nobody else's lack of planning constitutes an emergency on my part
If you plan to make pens on something that spins, you should plan to replace expendables, now and again
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor
Common sense isn't always such a common thing.
If it ain't broke.......then a little duct tape won't hurt it!
PenMan1 is offline   Reply With Quote Top
Old 02-17-2014, 12:01 PM   #15 (permalink)
PenMan1's Avatar
Photos: 93
Default
on a side note, my Jet 1014 VSI goes through so many switches, I was able to get Home Depot to keep that switch in stock for me. Same switch as the Jet OEM, SPST with spade lugs. HD price $1.97, Meyer (Jet Parts Distributor) $6.95 plus about that much in shipping.
The local auto supply store gets my business for Jet lathe belts, too.
__________________
Andy Little
Old 02-17-2014, 09:25 PM   #16 (permalink)
Photos: 0
Default
Wow! I'm soooo sorry that the Delta, in particular, the 460 lathe is having sooo many problems with the on/off/variable speed switch! I have several other Delta tools that I enjoy and use every day and wonder how many problems I'll have replacing necessary parts in the future.... Looks like one more great shop product that has gone the wayside. :>( For a weekend warrior, this is a big issue as I and I'm sure MANY others have these products in our garages and shops and have hoped they would last forever or at least have parts available when they break down... Wish we ALL had an easy solution...
Old Codger is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
delta , lathe , midi , parts , service
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
