Delta Midi Lathe 46-250
JRK
Bridgeton, Missouri
I inherited this lathe from my father. It has been sitting on a shelf until I recently decided to try pen turning.
When I got it out, I found that the belt needed to be replaced. It seems that a lot of parts from this lathe are no longer available. I was able to obtain a replacement belt.
Once I got it back together, it seems that the lathe is quite noisy, the higher the speed, the more noise it makes.
I am not sure if I did not get it re-assembled correctly, or if the noise is normal. I still have the instruction manual, and it is not very complicated...
I tried oiling the bearings, but it didn't seem to make a difference.
I was hoping maybe someone on here is familiar with this lathe, and might enlighten me.
Jerry
More4dan
Katy, TX
Try here for parts:
https://www.ereplacementparts.com/delta-46250-type-midilathe-parts-c-3275_9659_12777.html
Sounds like it could be the bearings. They should be sealed so it would be hard to get lube into them. Loosen the belt and test how smoothly the spindle turns. Also make sure the belt isn't too tight, usually 1/8"-1/4" deflection. You could also turn on the motor with the belt loose to check the motor for the source of the noise.
Danny
Dalecamino
Local Chapter Leader
Indianapolis, In.
I don't hear anything! :biggrin: Just joking with you. Those bearings should be sealed. So...a squirt of oil might not help. Can you feel any play in the spindle?
JRK
Bridgeton, Missouri
Try here for parts:
Danny
The lathe gets louder at higher speeds. This is not a variable speed lathe, speed control is by moving the belt left or right from pulley to pulley. So the motor runs at the same speed. I do not believe it is the motor.
I will see if the spindle has any play in it.
There are marks on the flange on the spindle. Looks like my father put a pipe wrench on it at some point. Not sure why...
Jerry
Gary Beasley
Marietta, Ga. USA
Its got a reeves drive. Those will make a lot of noise when they get wear on them, which is probably whats going on with yours. I used to run old Baum folders with reeves drives on them and they were wore out, noisy and sometimes hard to adjust the speed but they kept going.
JRK
Bridgeton, Missouri
I think I can still get bearings. Would new bearings help?
Jerry
Gary Beasley
Marietta, Ga. USA
Jerry
Yes it will. It wont get rid of all the noise because some of it is from the belt running on worn surfaces of the pulleys and the belt itself may have uneven wear. If you change the bearings you might want to see if the belt is available too.
Dalecamino
Indianapolis, In.
One other thing you can try is de-glaze the pulley surfaces where the belt makes contact. Use some fine sand paper and just scuff the shiny surface off.
