Cleaning oil off a new chuck? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 12-02-2018, 02:37 PM   #1 (permalink)
Herb G's Avatar
Photos: 18
Default Cleaning oil off a new chuck?
I bought a Nova Super Nova 2 chuck recently.
It's packed in a plastic bag inside the box & it's literally soaked in oil.
Does anyone have any recommendations for removing all this oil without messing up the finish or anything on this chuck?
I was thinking some Sprayway degreaser might do the trick.
Help?
__________________
Be happy in your work...Col. Saito
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Old 12-02-2018, 03:02 PM   #2 (permalink)
monophoto's Avatar
Photos: 0
Default
Some people like to use a detergent to completely remove the oil/grease. There are citrus-based detergents available at most supermarkets that will work for this purpose.
But I wonder if that is necessary or even wise. There's nothing wrong with leaving a thin layer of oil on the metal to prevent rusting. Obviously, you don't want to leave so much that it becomes a dust magnet or that your hands transfer oil to a turning. But it seems to me that a thorough wiping with an old shirt should be fine.
I would suggest using underwear, but people would tend to get anxious about whether it is clean.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is offline   Reply With Quote Top
Old 12-02-2018, 03:12 PM   #3 (permalink)
gtriever's Avatar
Photos: 3
Default
I wipe them down with a shop towel dampened in Acetone. Works good for cleaning my Morse Tapers as well.
gtriever is offline   Reply With Quote Top
Advertisement
Old 12-02-2018, 04:57 PM   #4 (permalink)
Terredax's Avatar
Photos: 4
Default
Quote:
Are you referring to the underwear, or the chuck?
__________________
-John-
Terredax is offline   Reply With Quote Top
Old 12-02-2018, 05:08 PM   #5 (permalink)
lorbay's Avatar
Photos: 134
Default
Anything that comes from off shore is coated with a packing or shipping oil and it very sticky.
When I get these parts and as did my new lathe I washed it all down with mineral spirits or paint thiner. Then I lubed all the nessasary parts with my oil.
Lin
__________________
"If you come to a fork in the road Take It."
Yogi Berra.
lorbay is online now   Reply With Quote Top
Old 12-02-2018, 06:17 PM   #6 (permalink)
gimpy's Avatar
Photos: 4
Default
You can send it to me, I’ll clean it for ya. lol
Spray away works good. But don’t clean it to good as
Lube is your friend
gimpy is offline   Reply With Quote Top
Old 12-03-2018, 05:05 AM   #7 (permalink)
Herb G's Avatar
Photos: 18
Default
I used some of this stuff. It worked fine. The oil it was soaked in was thick & viscous.
Industrial Heavy Duty Orange Power Plus | Sprayway Inc., Pioneers in Aerosols since 1947
This stuff took it right off. Here's a tip: Spray it on top of old newspaper.
The oil soaked right in & didn't make a mess on my workbench.
__________________
My lathes:
Floor Lathe
Bench top lathe
Old 12-03-2018, 08:35 AM   #8 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Before we had spray everything, folks would simply place something like this in a bucket of kerosene and come back the next day and let it drain and wipe it off.
This was also used for clocks that needed servicing...dunk the clock works, soak, drain, let dry and then oil the pivot/ bearings.
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 12-03-2018, 08:40 AM   #9 (permalink)
TonyL's Avatar
Photos: 6
Default
I bought and had to do the same. I don't know if this is right, but I used WD 40 and shop towels. It took a few tries. I did the same with my first nova chuck 4 years ago and it is still operating smoothly. Enjoy the new chuck!
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 12-03-2018, 11:14 AM   #10 (permalink)
WriteON's Avatar
Photos: 0
Default
I like to use https://triflowlubricants.com/produc...reaser-cleaner or BirchWood Casey Gun Scrubber
Please use the solvents outdoors and wear some kind of protective eyewear & gloves. This stuff is brutal to breathe and not good to get on skin.
However I simply wiped my Nova G3 dry/clean and started using it.
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool professional pool cue repair lathe
WriteON is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
