tonylumps
For those who have used either or both.Other than price.What is the biggest difference between the G3 With Pen Jaws and the Vicmarc 120 with Pen Jaws.The price is not saddle I was wandering about performance
Even though the Nova has done a good job so far.I am looking at more precision in the process of making a Pen and thought that drilling a blank is the best place to start.It seems like a lot of money just to drill a blank .But bolting a set of jaws to a precision chuck is the start a new turnig process for the New Year
I have a set.And was thinking about giving it a try.I do not mind the extra step of turning the blanks down for higher end PensFor more precise drilling you might want to consider a collet chuck. I always use this for drilling.
Lin
Does any one else prefer the EZ wood chucks to the Vicmark or Nova. I know Fish knows quality.
I never considered EZ wood chucks. I like changing things quickly versus buying a 6th dedicated lathe LOL.
Spent quite a few Hours on that with Brass shimming stock and an alignment bar.Took th whole headstock off .Cleaned ,shimmed and Remounted it.It is as good as I could get itEven though the Nova has done a good job so far.I am looking at more precision in the process of making a Pen and thought that drilling a blank is the best place to start.It seems like a lot of money just to drill a blank .But bolting a set of jaws to a precision chuck is the start a new turnig process for the New Year
I think you are looking in the wrong place.
Any chuck that holds the blank without wobbling is good.
Unless your definition of "precision" is limited to "makes an entry hole at the exact center of the blank", the place you really need to look is at the other end of the lathe.
To drill a round and true hole through the blank requires the drill bit to be perfectly aligned with the axis of rotation. That means the tailstock must be aligned to the headstock (possibly requiring the headstock to be adjusted too), and the chuck holding the drill must advance in a straight line along that axis.
I am trying to eliminate the faults of a wood lathe turning small Diameter stock.A metal lathe is just not going to happen for me.Even though I have been researching itFor the best drilling process, I have found that turning the blank between centers to 3/4 diameter or 5/8 diameter depending on the blank size. I then go to my collet and use the correct collet to hold the round blank.
I start with a center bit to get my hole started, then I use what I call a machinist bit, it is shorter than a jobber bit and I "think" less prone to wandering. Then finish drilling the hole with a jobber bit.
Wood lathes are not accurate, they are hand grenade close or horseshoe close. The same goes for the wood lathe chucks. When you combine the 2 together it is a machinist's nightmare. In fact chucks for wood lathes are a relatively new thing, in the last 40 years they have come a long way, but spending a fortune on an accurate chuck to put on a wood lathe is like trying to make a purse out of a sow's ear.
Looked at it Tony.But was afraid there would be too much play for what I need
Vicmarc with there Pen JawsQuote:
Thank you Tony. What did you decide to go with please?
