Chinese Laser - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 06-18-2018, 06:55 AM   #11 (permalink)
Photos: 2
Default
Quote:
Originally Posted by larryc View Post
That's what I like about the Glowforge. Air and coolant are completely enclosed.
Would like one of those!!
__________________
Keith Byrd, Mount Wolf, PA 17347
keithbyrd is offline   Reply With Quote Top
Old 06-18-2018, 06:56 AM   #12 (permalink)
Photos: 2
Default
Quote:
Originally Posted by hanau View Post
Have you been to the k40 laser facebook page?
https://www.facebook.com/groups/888394261237059/
Thanks for the link! -- Sent a request to add!
__________________
Old 06-18-2018, 08:07 AM   #13 (permalink)
TonyL's Avatar
Photos: 6
Default
I have no idea how safe this is or how the whole cooling thing works, but how about a single drop of chlorine bleach in the water?
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Advertisement
Old 06-18-2018, 09:46 AM   #14 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Hey, Keith, what is the source of your water? Is it city water, well water or a cistern. Do you have a water softener of any other treatment/filter on your household water system?
__________________
New Contest for 2019 BASH!
FINAL VOTE in what is considered the fairest, best balanced competition for all members:The PRETTY RESIN PEN CONTEST http://www.penturners.org/forum/f422...l-vote-158738/
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 06-18-2018, 10:05 AM   #15 (permalink)
KCW
KCW's Avatar
Photos: 13
Default
I don't know if this will help, but I have some high dollar equipment in my testing lab that uses distilled water, with and additive, for cooling (the additive is basically waterbed conditioner). I don't have the laser you are speaking about, so I don't know if there would be any issues in that instance.
KCW is offline   Reply With Quote Top
Old 06-18-2018, 04:46 PM   #16 (permalink)
Photos: 0
Default
Use this link and save some money.
https://glowforge.us/rTevKu
larryc is offline   Reply With Quote Top
Old 06-19-2018, 12:25 PM   #17 (permalink)
Photos: 150
Default
Use an enclosed container so that the water is in complete darkness. You can also used distilled water which will help. I use a large 10 gallon storage container with distilled water. I change the water once per year. Honestly no problems at all. I think I have had my laser for 3 years now. Distilled water will help a lot. No need to hook it up to faucet. Hope that helps.
__________________
Ron
Pens by Ron
http://www.pensbyron.com
brownsfn2 is offline   Reply With Quote Top
Old 06-21-2018, 10:31 AM   #18 (permalink)
Photos: 2
Default
Quote:
Thank you Ron! That seems to be the simplest answer! Now the next question - do you put the pump in the water container and drill holes for the lines to the laser?
__________________
Old 06-21-2018, 11:53 AM   #19 (permalink)
Photos: 1
Default
I use a 5 gallon bucket with distilled water and a harbor freight pond pump. I also have a water flow meter if it doesn't detected the water movement it will not let the laser fire.I had a pump go out and and killed the laser tube so I found a meter and installed it. Which i need to order a new one since the meter died.
this is the one i used.
https://www.lightobject.com/Water-fl...tion-P815.aspx
__________________
John
Carbide turning tools and replacement inserts.
www.ncwoodturningtools.com
or
find me in the Vendors Forum.
http://www.penturners.org/forum/f389/
hanau is offline   Reply With Quote Top
Old 06-21-2018, 12:58 PM   #20 (permalink)
Photos: 150
Default
Quote:
Yep. Absolutely. I drilled two holes. One to pump water out and one for the return water. Also use a thermometer to determine the water temp and make sure it doesn't overheat. Make sure the outgoing and incoming water holes are far apart or you will not give it time to cool. I use a container that is large and rectangular to create large surface area for heat to be reduced. Hope that makes sense.
__________________
Ron
Pens by Ron
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
