MrBubblehead
So last time I used the lathe I noticed an odd noise and didnt think much of it. Today I went out to clean the shop and investigate the noise further. I found a bearing had failed in the reeves drive speed adjuster and broke the lip off of the pulley on the spindle drive.
Jet lists the replacement part but king does not. I was wondering if one of you with a jwl1236 lathe could measure the spindle shaft size, before i order the Jet part. I also sent kind an email using the part number that king provides
Thanks a bunch.
Thanks a bunch.
