Benchtop Compound Table Router Drill
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
A little while ago I needed to buy a 16mm chuck to make a gadget for my metal lathe. Instead of buying a chuck on it's own, I bought a complete new benchtop drill press indentical to the one I already had. The Chinese DP was only about £10 more than the cost of a half decent chuck.
The old motor became a drum sander and the rest of the pulleys etc will eventually be used on other projects.
I've had a compound table for years and is a very useful tool but It takes up space and is very heavy.
I removed the DP base and mounted the column on a thick ali plate. Then I mounted the compound table behind it. I used the old DP bed clamp to hold an articulated arm which holds a router.
The old DP quill and chuck became an indexable rotary table.
Just by swing the drill press head around gives me several options
Here's some pics:biggrin:
rjwolfe3
Mansfield, Ohio, USA.
Looks very complicated. I wish I had the ability to do cool stuff like that. I wear zippered shoes because tying them is too complicated, lol.
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Add a couple of stepper motors and you'll have a really cool machine.
BTW - nice looking router - what is it and what size bits can it hold?
skiprat
In a Skip in Wales
Bruce, I've got a few full sized ( 1/2 inch ) branded routers, but this Chinese budget one is my favourite by far. It has collets to take 1/4 (6mm) and also the little Dremel sized ones. I think they are 2.5mm and 3mm.
I came with an adjustable footplate and I think it was meant for cutting holes in drywall ( plasterboard) I love it.:biggrin: I lost the footplate ages ago, but it has a flat round 42mm collar that makes mounting it easy.
LOL, automating the x-y table DID cross my mind, but I would need to change the leadscrews as they are too sloppy for bi-directional cuts. Of course I still need to remember to wind in back a bit to take up the slack.:rolleyes:
skiprat
In a Skip in Wales
Charlie, we have no moons on my planet but there is a blue and brown overpopulated 'thing' that revolves around us:wink::biggrin:
We are thinking of sending a little manned rocket to pay it a visit, but will probably just end up making a movie:biggrin::biggrin::biggrin: as it doesn't look that great from here.:wink:
NewLondon88
Local Chapter Leader
Claremont NH
Don't waste the fuel. They'd never make it past customs, anyway..
.. and if they bring toothpaste or shampoo, forget it!
OKLAHOMAN
Costa Rica
Damn....why didn't I think of that.................
Oh now I remember, because I wouldn't know what the hell to do with it.:confused:
el_d
Lockhart, Tx, USA.
Nice work Skippy!
And to think , I an having a hard time trying to find a "elegant" solution to take apart a long click.....
Canada
AHA! That's how you did that cool "Don" pen machining. I was trying to mentally design a router table jig and marvelling at the accuracy you achieved. Very ingenious my friend. I am inspired.:good::good:
glycerine
Fayetteville, NC
Skip, I'd like to hear more about the drum sander you made with the old motor, as I currently have an unused motor out in the garage. Did you use pillow block bearings and then make your own cylinder to attach the "sandpaper" to?
nava1uni
San Francisco, CA, USA.
Amazing set up. I wouldn't know where to begin.
I definitely feel like you guys are from a different planet. No machining background, and the things that I make or come up with to do projects are primitive by comparison. It does however, make me think beyond the box and now I think I must take a class in machining, design, welding, etc., etc., etc. Guess I will have to retire so I can do it.
rej19
Indianapolis, IN
No wonder I can't get my pens to look like yours. I don't have one of those things. Do you have the instruction manual? :confused::confused::confused:
Just kidding of course! Except for the looks of my pens.
glycerine
Fayetteville, NC
I've been wanting to do some welding myself... but looking at welder prices, that's a whole 'nother chunk of ca$h that I don't really have to blow right now!
