Berkshirepens
I own a barrel trimmer kit from PSI. The 7mm cutter shaft is worn and slightly bent. PSI says it cannot supply a new shaft as a replacement part. Several suppliers who sell 7mm shafts cannot guarantee that their 7mm shaft is compatible in size with the PSI cutter heads. Apparently this is because the shanks on their shafts may be slightly smaller than the PSI offerings. Does anyone out there know of a supplier whose 7mm cutter shaft works with the PSI cutter heads?
