Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Reply
Old 02-16-2012, 10:19 PM   #1 (permalink)
Photos: 0
Default Band Saw issues: Back with a vengeance
So after tuning up my band saw, per everyone's suggestion here, the saw worked amazing for about 4 cuts.
Now it bogs down with even the slightest pressure...as it stands, it would probably take me 5 or 6 minutes to cut a blank! Obviously something is not right here....but what?
I notice that the problem seems to get better if I put more tension on the blade...but I've heard that too much tension can cause the blade to snap, and that is not something I'm interested in happening!
When shining a light on the blade and looking side-on, I notice that while it's getting up to speed when I first turn it on, the blade seems to wobble slightly forward and back. I'm not sure if this is related to the problem or not.
All this trouble makes me want to go back to a miter box and hack saw :(
Scooley01 is offline   Reply With Quote Top
Old 02-16-2012, 10:31 PM   #2 (permalink)
PenMan1's Avatar
Photos: 57
Default
Sounds like the belt between the motor and bottom wheel has stretched or needs tightening.
__________________
Andy Little
entia non sunt multiplicanda praeter necessitatem. The popular interpretation of this principle is that the simplest explanation is usually the correct one. -Occam's Razor
Common sense isn't always such a common thing.
If it ain't broke.......then a little duct tape won't hurt it!
PenMan1 is offline   Reply With Quote Top
Old 02-17-2012, 05:55 AM   #3 (permalink)
PTsideshow's Avatar
Photos: 0
Default
Yes the drive belt would be my first look, Take it with you to any good auto parts store they will have a device to measure it. If the numbers are hard to read on it. They will be cheaper than at a tool place, and contrary to some places online for a regular V type belt they are the same!
Also recheck all your adjustments above and below the table, make sure they are tight. The bearing behind the blade on my import kept loosening up. The thumb turn screw was worn. I have found that the speed at which you can cut harder/denser woods on a band saw is a lot slower than I think it should be. That is why I'm working on my table saw to do most of the cutting with a thin kerf blade.
PTsideshow is offline   Reply With Quote Top
Old 02-17-2012, 06:07 AM   #4 (permalink)
Daniel's Avatar
Photos: 16
Default
to little tension on the blade is also bad. I would check the belt as well.
__________________
Daniel
Reno, NV
I love my computer, my friends live in it.
Daniel is offline   Reply With Quote Top
Old 02-18-2012, 07:28 AM   #5 (permalink)
Photos: 0
Default
I don't mean to sound silly, but are you sure you installed the blade facing in the correct direction (i.e., the teeth/gullets pointing down)?
I once inadvertantly had a thin blade turn inside out and I installed it upside down. It cut for a few moments because the wood was scraping against the sharp teeth.
So, just one more thing to check.
AlanZ is offline   Reply With Quote Top
Old 02-18-2012, 07:40 AM   #6 (permalink)
PenMan1's Avatar
Photos: 57
Default
I would throw away the v belt and get a link belt. Not only can the link belt be "tweaked" to perfect tension, it will run with considerably less vibration, last forever and will not develop a "memory" that causes a "wiggle" in bandsaws that get infrequent use.
These belts are a little expensive (about $6 per foot), UNLESS you calculate in the improved performance AND not having to buy belts again.
__________________
Andy Little
Old 02-18-2012, 09:07 AM   #7 (permalink)
Photos: 2
Default Rubber Wheels
One other thing to check is to make sure the rubber wheels are good and not slipping.
DAMHIKT
cmccarter is offline   Reply With Quote Top
Old 02-19-2012, 06:06 PM   #8 (permalink)
Carl Fisher's Avatar
Photos: 13
Default
Been there, done that.
__________________
Carl Fisher - Fort Mill, SC
Carl Fisher is offline   Reply With Quote Top
Old 02-23-2012, 01:42 AM   #9 (permalink)
Photos: 0
Default
Blade is facing correctly...it was the first thing I checked, haha!
The belt is a tiny little thing the goes from the motor to the lower wheel...and it seems to have a LOT of slack in it, which can't be good. I can push in a good inch or so on it. I imagine this belt should be taut, correct?
Old 02-23-2012, 05:31 AM   #10 (permalink)
PTsideshow's Avatar
Photos: 0
Default
Short answer yes, Depending on what kind of profile the belt has you generally can get any V belt @ a well stocked Auto parts store. Along with a better price. They generally are the same belts just not branded for the equipment.
Also as been stated on this forum before check out those link belt adjustable drive belts as they are worth the money and adjusting them is a lot easier the the regular ones. Next one I get will be a link type belt.
Woodcraft,Lee Valley etc. sell them.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
