40W lasers discussion - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Shops, Jigs, Fixtures & Tools
  Forgot Password
Shops, Jigs, Fixtures & Tools Show off and discuss your workshop and everything in it.
Welcome to penturners.org!
Reply
Old 05-26-2016, 01:43 PM   #21 (permalink)
Carl Fisher's Avatar
Photos: 10
Default
I'm currently working with someone who has a 3D printer and a design for a different style of targeting laser. This one will allow a single dot laser to fire into the secondary mirror and paint an accurate target through the laser head while the lid of the machine is open. When you close the lid it will pivot the targeting laser out of the path of the main laser.
I'm finding that I don't like the way my targeting laser is setup as it can vary if your not targeted right at the focal length of the work piece and it's skewed since it sits off to the side of the laser head.
The new one should remove all of that guess work.
You can see a version of it on Thingiverse here: http://www.thingiverse.com/thing:1002341
__________________
Carl Fisher is offline   Reply With Quote Top
Old 05-26-2016, 03:55 PM   #22 (permalink)
mecompco's Avatar
Photos: 9
Default
You can see a version of it on Thingiverse here: Laser pointer for K40 Chinese CO2 Laser by ThorMJ - Thingiverse
Very cool, and I have access to a 3D printer. Now I want a 40 watt unit! Sadly, the wallet is a bit flat ATM.
mecompco is offline   Reply With Quote Top
Old 06-03-2016, 07:02 AM   #23 (permalink)
BradG's Avatar
Photos: 98
Default
Hey Carl,
Thanks for creating this thread. I couldn't see it yesterday hence why I started one - have since asked for it to be deleted
Just food for thought, but an anodised metal pen can have the anodising removed by laser. We may not be able to etch metal at these powers, but I would think stripping anodising would be a better approach than using the marking compounds which as you said, may wear off with time. Anodising is pretty permanent as you know. Needless to say I'm looking into this so I can put names on my pens professionally, but id like to experiment with graphic effects too.
I've been eyeing up this one. Quite a price jump for the one you're using. Would you mind having a read to see what you think?
PRO 50W CO2 Desktop USB Laser Engraving Cutting Machine Cutter Engraver | eBay
This one comes with a Rotary attachment.
Could I ask what you do with regards to the water cooling?
BradG is offline   Reply With Quote Top
Advertisement
Old 06-03-2016, 07:21 AM   #24 (permalink)
Maverick KB's Avatar
Photos: 7
Default
I would be concerned about 2 things off the bat.
1. The width of a focusing laser may not match the diameter of the laser from the tube and therefore you may not get an accurate focus on your Z axis.
2. The laser and pivot arm would have to be mounted to the case and not the lid as the lid may have too much play in the hinges over time and not rest in exactly the same place. That would mean a mechanical lift arm in the way of my gantry, but you might have more room than me.
For these reasons I'm more a fan of two dot lasers on either side of my laser head (3D printing a mount is easy) placed at a calculated angle so that the dots overlap at a fixed focal point. I have a motorized bed for Z axis, so I would simply raise or lower the piece until my red dots join. Then I have not only my focal point but also my virtual zero if I'm trying to hit a specific point on a piece of material.
Just my preferences as food for thought.
edit*
Here are the focusing lasers i picked up. They work quite well and the individual focus on them helps with macro adjustments in the 2 laser setup.
http://www.lightobject.com/5mW-650nm...oint-P585.aspx
The mod you mentioned is a simple version of a beam combiner. Like this http://www.lightobject.com/Laser-mac...ter-P1000.aspx
Certainly not a bad way to go, I just liked this option better... something like this: http://www.thingiverse.com/thing:558587
__________________
Ken Bandoly
Tinkerer & maker with a slight pen obsession
Visit our Amazon storefront
For lower prices than Amazon, greater selection and exclusive deals...
http://shedlifellc.com
Maverick KB is offline   Reply With Quote Top
Old 06-03-2016, 07:37 AM   #25 (permalink)
Photos: 7
Default
Here are some of the upgrades i used on mine:
New brains! No more Moshi. That board and software was so bad on mine it was this or the dump.
X7 DSP upgrade kit for D/K40 small CO2 laser machine
I put the motorized bed in. This was a game changer!!!
Power table/ bed kit for K40 small laser machine
In the end, I probably over spent and could have built a better bigger one from scratch, but I learned a lot. I also upgraded the water pump with a pond pump from Lowes, upgraded the exhaust fan, replaced the mirrors & the focusing head, added air assist and zero stop switches... basically, I only kept the case, the laser tube and the X, Y gantry (which I had to modify so it ran true).
I may build a new frame and gantry system and transplant my guts for a larger work area. Then, when my tube dies, i can replace it with an 80W tube or better.
See... it never ends...
__________________
Ken Bandoly
Old 06-03-2016, 09:40 AM   #26 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Quote:
Be aware that laser-engraving anodized metal does not simply remove the anodizing. I've engraved a variety of anodized aluminum items (dog tags, flashlights, pocket knives, etc.). The laser leaves a white mark, not silver. Also, the mark tends to flow a little, so don't expect the same resolution you can get on other materials.
I hope that helps,
Eric
__________________
Eric Rasmussen
http://www.erasmuspens.com
Rifle cartridges (bullet pen kits) for penturning available at:
http://www.bulletpenkits.com
Sylvanite is offline   Reply With Quote Top
Old 06-03-2016, 09:43 AM   #27 (permalink)
BradG's Avatar
Photos: 98
Default
I hope that helps,
Eric
Hi Eric. what wattage laser do you have?
I am aiming for this level.
Old 06-07-2016, 03:00 PM   #28 (permalink)
Photos: 4
Default
Carl,
What do you think of this version of the 40W CO2 laser:
40W CO2 Laser Engraving Cutting Cutter Machine ENGRAVER USB Port High Precise | eBay
Do you feel that the upgraded controls included are worth the extra money as a starting point?
Nick Rocco is offline   Reply With Quote Top
Old 06-09-2016, 01:30 PM   #29 (permalink)
Turned Around's Avatar
Photos: 0
Default
that seems like a reasonable price. wonder how that one performs. didn't see any examples on the page.
__________________
Nic
www.turned-around.com
Turned Around is offline   Reply With Quote Top
Old 06-09-2016, 08:56 PM   #30 (permalink)
Photos: 10
Default
Quote:
Originally Posted by Nick Rocco View Post
Carl,
I've been following a bit of talk on the newest version on the market, but so far nobody has owned up to buying one.
It has some neat upgrades but I have to wonder if they are quality upgrades or just something thrown in cheaply to try to get a leg up in a very competitive market.
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
