wood-of-1kind
For those members that use the BEALL CHUCK to turn pens. What size of ER collect do you use? The "B" mandrel (0.290") that I use has been giving me problems in terms of matching to a proper collet size. The closest match so far is a size 8 mm (8-7 or 5/16"). In order to get a good grip I have to wrap some masking tape to build up on the diameter of the "B" shaft. Would be interested in your comments in terms of what you are doing to use the Beall chuck the way it was meant to used.
Thanks in advance for your input.
-Peter-
-Peter-
