bjbear76
I'm familiar with the results of introducing water when applying a CA finish, I get the tell-tale sign that water found a way between the CA and the wood.
This time I avoided that issue and dry sanded all the way through the MM pads.
Yet I still found a couple small spots on the ends of the blanks which look exactly like water got under the CA.
My initial thought was maybe I got some Novus under the CA. Possible? Likely?
If so, from what I've read from you guys is:
1) seal the ends of the blanks with thin CA
2) don't use Novus and use the buffing wheel
Am I am the right track? Which would be the preferred method and are there other options?
