Wood grain - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Old 06-17-2017, 02:54 PM   #1 (permalink)
Firebucket53's Avatar
Photos: 5
Default Wood grain
What can I do to make the wood grain pop on my pens? I've used a CA glue finish which works great but it really doesn't bring out the grain. Looking for any suggestions.
Thanks in advance for your help.
Of all the things I ever lost I miss my mind the most.
Firebucket53 is offline   Reply With Quote Top
Old 06-17-2017, 04:59 PM   #2 (permalink)
JimB's Avatar
Photos: 11
Many people, like myself, use BLO (boiled linseed oil) with CA when doing a CA finish. When I do it, I use a drop or 2 of BLO on paper towel and wipe on with lathe on or off. Wipe off any excess and then apply your CA. I then repeat BLO then CA as many coats as a I desire.
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 06-18-2017, 12:15 PM   #3 (permalink)
Photos: 0
Nice to know, Jim. Will be applying this method on my very next pen. Thanks for sharing.
God Bless,
NLAlston is offline   Reply With Quote Top
Old 06-18-2017, 12:29 PM   #4 (permalink)
Photos: 1
Disclaimer : I hate CA finishes on wood, unless there's a special reason to use it. A soft Burl comes to mind as one of those reasons.
Otherwise, depending on what type of wood it is, to make the grain pop I use either BLO, Birchwood - Casey Tru-Oil, or Minwax Natural Stain / Minwax Wipe-on Poly. I follow those up after they cure with a buffed coat of Johnson Paste Wax.
I know they're not as long-lasting as CA, but IMO wood should feel like wood.
gtriever is offline   Reply With Quote Top
Old 06-18-2017, 03:13 PM   #5 (permalink)
New Member Advocate
Edgar's Avatar
Photos: 23
I sometimes use BLO, but I generally prefer teak oil. I mostly use teak oil when I want to enhance the look of the grain & if I don't get the effect I want, then I follow up with BLO. Maybe it's just my perception, it I think that teak oil doesn't darken the wood quite as much as BLO.
Eat pecans - 10,000,000 squirrels can't be wrong.
Edgar is offline   Reply With Quote Top
Old 06-18-2017, 03:55 PM   #6 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Some woods, outside of knots and spalting, don't lend themselves good to showing grain well. Contrasting grain, knots and burls do well. I have some huan pine from Tasmania that is beautiful wood an smells great but the grain is so fine that it is hard to see it. I made a couple of pens that had about 100 years of growth difference in the inner vs outer ring/grain. But it didn't show up well in the pen unless looking very close.
I love teak in furniture, but the beauty of the straight gold grain is lost in the small area of a pen.
If you have an unturned blank, sand the sides smooth and try light stains and different oil finishes on an area to see how they either mask or enhance the grain.
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 06-27-2017, 12:13 PM   #7 (permalink)
Photos: 0
Default your technic
Is it possible that you are over sanding your wood, making the wood dull before you ever put the finish on ?
Loading up the water pores in the wood with saw dust and dirt therefore dulling the wood ?
Are you sanding across the grain or with the lathe on .
I don't sand past 420.... and depending on the wood , some woods you never sand across the grain ..
half worn out sand paper will dull the grain.
I vacuum out the dirt and dust before I apply a finish ...
farmer is offline   Reply With Quote Top
Old 06-27-2017, 02:00 PM   #8 (permalink)
Photos: 4
Not a fan of BLO due to it’s inherent darkening wood with age.
Any film finish will pop the grain whether imparts an amber hue all about finish you select. That is why there is not one single finish for all wood species. Have to experiment with different finishes!
Wood species selection and how you cut the wood will also help add dramatic effect. Keep in mind regardless of finish used some species of wood will darken with age and some lighten naturally regardless of finished used! Time frame for darkening and lightening of wood happening may or may not occur in our life time.
Wildman is offline   Reply With Quote Top
Old 07-06-2017, 07:18 PM   #9 (permalink)
Marmotjr's Avatar
Photos: 0
I've also done paste wax, danish Oil, mineral oil, and shellac under CA finishes.
It depends on the wood and the grain.
I also sometimes wet down the wood with water after my highest sanding grit, let it dry, and sand it again. This raises the grain and then removes it, helps make for a smoother surface IMO. But under a CA finish on a pen this is really not necessary.
I also use DNA or mineral spirits to clean the wood surface of dust and particles after sanding.
The only true way to get a correct response on the internet, is to post an incorrect one yourself. Hence why I post a lot.
Marmotjr is offline   Reply With Quote Top
Related Content
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
