Wet sanding wood? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 06-29-2018, 06:48 PM   #1 (permalink)
Photos: 17
Default Wet sanding wood?
Probably a very dumb question, but they say the only thing dumber than a dumb question is the dumb guy who doesn't ask it.
I keep seeing mentions of wet sanding. I'm a newbie with only 8-10 pens under my belt, but I'm trying to learn as many techniques as possible. My first five pens were all dry sanded and micromeshed down to 12000 and then CA-finished. They all came out amazingly.
Then I decided to try wet sanding. Is this perhaps actually only for acrylics?
I've tried a few now, and no matter what I do, the wood grain raises up as the wood gets damp. That's to be expected, of course, but I figured the problem would go away as the grits continued getting smaller.
And it does, for a little while, but even going all the way down to 12000, the nice smooth wood gets fuzzy again after a short while. The only way I've found to save the pens is to let them dry and then start over with dry sanding. So the wet is doing nothing but wasting my time at the moment.
What am I missing? I'm sure this probably works great on acrylics, but do people do it with wood? If so, how do you get it to where the grain stops raising? And what is the advantage of it over dry sanding?
Marshall
mgatten is offline   Reply With Quote Top
Old 06-29-2018, 06:57 PM   #2 (permalink)
Group Buy Coordinator
Monty's Avatar
Photos: 13
Default
I only wet sand on acrylics or after I have put CA on the wood.
__________________
Mannie - Pearland, TX
I hate it when people steal my ideas before I think of them.
Monty is offline   Reply With Quote Top
Old 06-29-2018, 07:09 PM   #3 (permalink)
TonyL's Avatar
Photos: 6
Default
I did, what Monty does. Also, there are plenty of folks here that are delighted to answer any question. Enjoy your turning.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Advertisement
Old 06-29-2018, 07:11 PM   #4 (permalink)
mark james's Avatar
Photos: 484
Default
As with Monty, I only "wet" sand with water on acrylics or similar - 2 hrs ago it was truestone/aluminum.
But... I do sand some wood blanks with walnut oil, linseed oil, etc... This is when I will usually leave a matte finish. There are many varieties available online.
It will be a matter of what you want the final appearance and feel to be.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 06-29-2018, 07:33 PM   #5 (permalink)
Photos: 1
Default
You can wet sand wood but not with water. You would use an oil like Boiled Linseed Oil (BLO) with the medium/finer grits to form a slurry to fill pores in the wood.
Warning! Warning Will Rogers! Spontaneous combustion can occur with sandpaper and rags with finishing oils on them so get them out of the shop and spread them to dry or submerge them in a bucket of water.
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 06-29-2018, 07:45 PM   #6 (permalink)
Photos: 0
Default
If I am turning wood and plan on finishing with Danish oil or teak oil I sometimes wet sand with either Danish oil or teak oil. As to acrylics I use automatic transmission fluid for my wetting agent whne wet sanding.
dogcatcher is offline   Reply With Quote Top
Old 06-29-2018, 07:46 PM   #7 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
I rarely wet sand pen blanks. Some people do, some don't.
The professionals that don't - will have just as effective and beautiful of a finish as the professionals that do.
If it helps you, do it. However, a warning: in cooler weather such as around 75 and below, moisture in the wood can come to the surface under the finish (CA) and cause cloudiness. It does not always do that but it does it on occasion.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 06-29-2018, 08:36 PM   #8 (permalink)
mark james's Avatar
Photos: 484
Default
Sorry Old Man... Will Rogers was a tad before "Will Robinson"... (Yes, I know what you meant, and we are probably close in age!) But yup, the rags will still ignite!
__________________
Check out the
IAP Collection
Old 06-29-2018, 08:56 PM   #9 (permalink)
Photos: 0
Default
How did you get the CA to stick after you sanded to 12,000 ???
__________________
* The above post most likely has not been proof read nor grammatically correct. Spelling, ehh, 50/50 with spellcheck*
Have a Blessed Day, ivel
ivel is offline   Reply With Quote Top
Old 06-29-2018, 09:18 PM   #10 (permalink)
Photos: 1
Default
Quote:
I swear I typed Robinson when I was answering. Must have been that Smith guy that changed it after I proof read it. ;)
__________________
Pete
Related Content
Reply
Bookmarks
Tags
finishing , sanding
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
