Allen_B
I am looking for different techniques on how to use Woodturners Finish. I can't find any in the Library here on the forum or anywhere else. I was needing some guidance on this. I dont really get any help from reading tutorials and trying those techniques. Any help would be appreciated. I'm more of a see it then do it and not read it then do it kind of guy.
I apply it after I've sanded to 600 grit. I put about 7 thin coats on the blank and let it dry for almost two minutes between coats. Then I use MM starting at 600 and this is where it falls apart. The blank looks like its covered in milk. Am I sanding too long and too hard with the MM?
