UV Protection
greggas
North Easton, MA
I was wondering if anyone knew of a way to provide UV protection prior to applying a CA finish. I'd like to find a way to keep woods like Osage orange, mulberry and purple heart from changing color over time.
thanks for any input
bradh
Aurora, Ontario, Canada.
That's tricky. I spent some time trying, but no luck. I found out most UV protection finishes block the UV with solids, which does not work well when you are trying to show off what is under the finish.
I also tried using Armour-all which claims good UV protection. It is loaded with Silicon type chemicals and it is tough to get any finish to stick to it.
Good Luck.
woodgraver
Federal Way, WA
I think Penofin Oil would be the answer to your problem. www.penofin.com
I have used the Marine Penofin Oil on purple heart furniture I have made and then covered it with a laquer finish, so I expect you could also put a CA finish over the top. It has a 99% UV inhibitor. The only thing I'll say is that it does darken the wood, but in the case of purple heart, it looks really rich and has maintained its color for 5 years with no fading.
woodgraver
Federal Way, WA
If you can't get some in a small quantity locally to try it, let me know. I have a gallon of it and could make you up a little bottle and send it to you, no charge ;)
Jim
