Using slow-speed blank drying system - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 02-11-2019, 08:40 PM   #1 (permalink)
Photos: 0
Default Using slow-speed blank drying system
For Christmas I received a PSI slow-speed blank drying system from my daughter. Up to now I've used a fast-drying finishes like Mylands or Aussie Oil. Not wanting to disappoint her, I want to show her when she comes home in two weeks how I've put it to use and teach her to use it as well. Any advice will be greatly appreciated. I looked for a YouTube video but was unable to find anything relevant. Thanks!
mkemmet is offline   Reply With Quote Top
Old 02-11-2019, 09:02 PM   #2 (permalink)
mark james's Avatar
Photos: 484
Default
I use a slow speed system that I was gifted from Bruce Robbins (similar to the PSI one). I use it for wipe on polyurethane finishes. I have also incorporated it with a lamp in a box that increases the temperature, and keeps shop dust from adhering on the blank while it is tacky.
The drying system will keeps the coats uniform, the lamp speeds the drying.
Without this system, my time between coats was 3-5 hrs. With this system it is 1 hr. I do not sand between coats, which may help.
Finishes is not a strong element in my penturning, so be mindful to explore what works for you, and others will give their opinion.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 02-11-2019, 09:08 PM   #3 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Do you use mandrels?
It is like a mandrel, only it is mounted on one end. Put the blanks on, add finish or CA to the blank as you would if it were on a lathe and turn it on. It will turn slowly to keep the finish even as it dries.
Go to this site and off to the right you will see two smaller picts. Click on the smaller pict and it shows the set-up, which is like a mandrel set up.
https://www.pennstateind.com/store/PKDRY.html
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Advertisement
Old 02-12-2019, 11:21 AM   #4 (permalink)
Bob in SF's Avatar
Photos: 2
Default
Marlen - the slow-speed blank drying system has all sorts of uses whether it is running forwards or in reverse or alternating - drying, taping for painting including hand and airbrushing, coating with CA followed by sprinkled-on mica or other additives, use of alcohol inks followed by clear coating before tube-in casting; up-end it and clamp it to your bench to do vertical work including dripping of various colors, UV light curing of UV resin...the list goes on. Have fun!
Tiny example from one of my earlier posts:
Barreling Along with Some Interference (paints)
Warm regards - Bob
Bob in SF is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
blank drying system
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
