JonathanF1968
I'm planning on turning a coffee measure, ice cream scoop, and razor handle, and finishing with mineral oil and then beeswax. Basically, keeping them food safe.
Should I finish these off the lathe?
I'm curious how many coats of the oil I should do and how long to let it dry between coats. My experience finishing turned items is limited to friction-polish systems (such as sold by Woodturningz), where you do a series of wipe on/wipe off pairings essentially immediately without letting it dry first.
Would it make sense to really saturate the wood with the first coat, let it dry for, say, a day, and then sand it, and after that do a series of lighter coats of mineral oil?
A more general question: how to determine how many coats to use by looking at the workpiece. I'd imagine that different types of wood would require different numbers of coats. How do you know when you've done enough, other than following folk wisdom/old wives tales? What does "enough" look like?
Note: I keep bees, and would like to use my own beeswax, just to keep it in the family. I understand that carnuba wax would be more durable. What would you think of a couple coats of beeswax followed by a final one of carnuba?
