Katya
I see that Lee Valley has a special on true oil, saying it's usually put on gun stocks. Does anyone know if it would work as a pen finish?
On the first coat, let the Tru-Oil soak in real good, wet sand with your highest grit. The wet sanding will help to fill in any pores. The time frame between coats depends on temperature, humidity and how fresh the Tru-Oil is. I usually wait at least 24 hours, we have low humidity and temps are either mild or HOT.
For a good set of instructions look up Frank Whiton gunstock finish. There are a couple of them on the Internet, in my opinion are worth reading even if you do not use an oil finish.
