Munsterlander
I've quite happily gotten to the point where I can consistently get a CA finish with which I'm very happy (using the simple method of sand to 600 or sometimes 1800 grade MM, clean (I use accelerant), 10-12 coats of thin CA with a puff of accelerant between each coat, applied with the blank between centers, no bushings).
The biggest problem I still have is when I go to trim off the little bits of glue that go over the ends of the barrel I sometimes get the dreaded lift of the finish.
I've been using my barrel trimmer to do it, by hand, and I do it before I put the blanks back on the lathe to do final sanding/polishing so that the blanks sit flush against the bushings.
I know a lot of you do this very differently (e.g., CA applied with bushings, just snap them off (I have the same problem occasionally with that too!)), but what I'm really trying to find is does someone know the trick to avoid the lift applying the CA glue the way I'm applying it? e.g., would higher speed for the barrel trimmer prevent it, so perhaps I should stop doing it by hand and using my drill press or hand drill?
Thanks for any tips.
