A Top Coat For Brass?
RedBeard
NW Indiana
I have some spent rifle casings that I'm using to make some pens. I'd like to keep them from tarnishing over time and was thinking that a spray lacquer would suffice but was curious as to if anyone else has used a different product.
For what it's worth the wooden bits will be finished in either Wood Turner's Finish or BLO/CA.
Dalecamino
Local Chapter Leader
Indianapolis, In.
Clear powder coat works best. I tried laquer but when I tried wet sanding it just peeled off the cartridge. Eric Rassmussin (Sylvanite) makes awesome bullet pens with powder coat. He may even coat your s for you. Look him up in the members list.
SteveG
Eugene, Oregon 97404
I recommend that you check out Protecta by Everbrite (ProtectaClear.com). I am not affiliated with the company, but have used and like their product. It is easy to use, requires no special equipment, and they offer a product line for a wide range of metal appearance and protection.
vtgaryw
Milton, VT
I sell a lot of bullet pens, and I use the fact in my sales pitch that I don't coat them, I leave them natural and they will tarnish. Most people seem to like that. I do tell them that they can clean them up with a little brass polish from time to time if they want to though.
-gary
RedBeard
NW Indiana
I've decided on the raw brass approach. I'm only making a few (for now at least) and can't justify any special finish like powder coating etc, etc.
I ended up dry sanding with MM then a buffing with PlastX of all things had the brass nice and shiny. Any future polishing will be up to the end user.
mmayo
Tehachapi, CA
Need help with brass too
Boy do I want the here some solutions to this problem of brass corrosion other than baking on a finish.
I make these ("cedar plugs" for catching fish) and each one has a pure, raw brass end that will corrode in days. I have tried a couple of things including clear nail polish, BLO and finally BoShield. I am not happy yet.
Share your suggestions, but know this what it looks like at the end and that is when I need to either rub on or spray on the protective glossy finish. The wood has five coats of BLO/CA finish and looks great, but it does nothing to protect the brass from corrosion and discoloration.
Thanks in advance for your help.
Skie_M
Lawton, Ok
Wax.
Specifially, Turtle Wax hard coat car polish. You may want to try that, as it should give a waterproof clear finish on your brass, but you'll still have to re-apply it now and then and polish it up.
Also, you may want to think about changing the metal on the head to brass. When you have two dissimilar metals in contact with a catalyst (like lightly acidic water) you will have a lot of corrosion. Between those two metals, the brass is likely much more reactive and will tarnish and corrode MUCH faster. As long as the ENTIRE plug is totally encased and protected from water, the brass will tarnish as long as it's in contact with that other metal.
Skie_M
Lawton, Ok
The issues regarding corrosion were in reference to the fishing plugs in the post above mine. :)
In any case, Turtle Wax should work fairly well for both of you.
bkersten
Gettysburg, Pa. 17325
Here's something that my brother uses on metal and motorcycles that may work for you. Sharkhide
