Stickers and CA finish
Daddy1
Toledo, Ohio, USA.
I am making a pen for a Dallas Cowboy fan and decided to add a silver star sticker and seal it in with CA. Well the CA took the silver off the sticker. Is there a certain type of sticker I need to get? I have seen others do this. Is there a trick I'm missing?
csr67
Eastvale CA
or apply modge podge to the sticker and let dry before your CA finish
They still make Modge Podge? That's so 70's. :)
Curt
:biggrin:,yep. I bought some "Martha Stewart" decopauge elixir stuff at the craft store and used it to make a stamp pen last week. It worked perfectly. I slathered a coat on over the stamps that were glued on a turned wood blank, waited an hour, then built up a heavy CA finish. It turned out great!
csr67
Eastvale CA
Glad to hear that. Yes, once I realized I could seal a stamp or anything glued to a bare wood blank, then CA over it to get a nice pen, lots of options opened up!
Not sure about that prior comment regarding it takes 3-4 weeks for Modge Podge to dry. Maybe is you put on a 1/2" coat! I brushed a light coat over a stamp pen, let it dry one hour on a warm day, then did my CA finish. It turned out perfect with no issues.
CREID
Vancouver, wa
Don't take my word for it. Do like I did look on the website and cal the company and ask. It's a WATER based product. It does take time to dry.
I spent over 30 years in the inks and coatings business with the last 20 plus years specializing in water based inks and coatings ( modgepodge would be classified as a coating ). If ANY waterbased product put on at the thickness that would be used to coat something on a pen took 3-4 weeks to dry, it would never dry. I doubt very seriously that it would take 3 - 4 weeks to dry. I actually know the chemistry behind waterbased products. If I were you I would call the company and ask your question again and be more clear on what exactly you are asking.
Curt
Daddy1
Toledo, Ohio, USA.
So initially the modge podge worked good....but when I went to sand it it peeled off in layers. I switched to clear acrylic and had much better results. Here's what I did!
csr67
Eastvale CA
Are you applying CA finish over the modge podge once it's dried? I did the modge podge on my stamp pens, let dry, then did 2 thin, 8 med. CA coats. I then wet sanded to 12,000 MM pads and polished with Hut's on my buffer. No peeling of finish at all.
Daddy1
Toledo, Ohio, USA.
I am now working on the Cowboys pen and using acrylic but the process is S L O W. Trying to build up the coats so you can't feel the sticker and the pen in smooth and even. I think next time I will make the pen and just cast it in PR.
CSR67, I will give it another shot maybe. I'll apply it and let it dry for 1-2 days and see what happens.
