Some ramblings about finishes
RussFairfield
Passed Away 2011
Post Falls, Idaho.
I read the messages here about what will and won't work. This isn't something new. I have spent most of my life finishing wood of one sort or another. Along the way I was overloaded with information about the things that just will not work, and other things that I could take to the bank.
Some of the things that I was supposed to learn were that water and oil don't mix; incompatible finishes, solvents, and thinners shall always be that way, incompatible; shellac over lacquer won't work; neither will a lacquer over a wax; an oil will not stick to a lacquer; lacquer is no substitute for shellac, ever; shellac is not a good finish; lacquer is a difficult finish; and the list goes on and on.
The only thing that I learned from experience was that most of the things that shouldn't work, did; and those that were supposed to work, didn't. So much for the conventional wisdom. Every day I see finishing schedules that shouldn't work, and I use many myself that aren't supposed to work; but they ARE working, and they are are working very well.
I have come to two (2) conclusions. If the wood itself is polished to a smooth high gloss surface, it really doesn't matter what we put over it. And, we will always be disappointed when we depend on the finish to do it all for us.
I also have learned that there are things that I can do easilly, while others cannot; and that the opposite is also true. Using CA glue and Boiled Linseed Oil at the same time and getting anything that looks like a finish is one of those opposite things. The differences are often lost in the details. "I did it exactly like you said, and it didn't work". Maybe you really didn't do it like I said; but maybe you did, and my description was not complete.
Learning about finishing wood is like knowing more and more about less and less, until we start knowing everything about nothing; or, is that the other way around. Maybe I have had my head in the can of lacquer again.
BogBean
USA.
If the newbies would just read all the posts about finishes on this board they will find all the info they need to do a great finish. I have found two finishes that work for me and if it was not for the members posting what they have learned I would still be walking around in a fog. Thanks to all of you my learning curve was shorted by a bunch...
J. Fred Muggs
Easley, SC, USA.
If we all believed all that we've been told would not work or was the only way to do something would the world have ever seen an industrial revolution?? would we have ever escaped the stone age??
I believe <b>necessity</b> to be the mother of invention. <b>Laziness</b> (really the desire to do it easier) to be the father. And quite often, <b>ignorance</b> of the way we were "supposed to do it" is the midwife actually delivering the child.[^]
Gregory Huey
Fallston, Maryland, USA.
Russ
I was a finisher in a cabinet shop for years and have to agree with most of what you say. It seems like the more you think you know about finishing the more you find out you don't know. I find myself still expermenting with finishes every day. You a totaly right on one thing the better the sanding or polish on the wood the better the finsh will be. Just my 2 pennys
jdavis
longview, texas, USA.
Russ,
You are right about the sanding. Seems like never enough time spent sanding. Always in a hurry to get the product completed. What a shame.
