Segmented Turning Question - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 03-05-2016, 01:41 AM   #1 (permalink)
Photos: 0
Default Segmented Turning Question
Hello Everyone. I want to start by saying I have learned a lot by reading through your posts and tips. I have been an IAP member for only a short time, but have been turning pens since 2004. I only wish I had discovered this site years ago as I could have avoided some bad habits. I recently tried my hand at segmented turning, and created a blank using Ebony and Birdseye Maple. I was trying for highly contrasting woods in the pen, and all worked out well, but as I feared, when I began the sanding process, the dark ebony stained the grain of the maple. My question is, have you found any reasonable way to avoid this? I considered using a sanding sealer on the wood after turning it, but decided against it in the end - should I reconsider?
Any suggestions would be appreciated. Thanks.
Edge1202 is offline   Reply With Quote Top
Old 03-05-2016, 02:02 AM   #2 (permalink)
Photos: 0
Default
You will always have that problem unless you fill the grain. You can also try a coat of thin CA before you start the finishing sanding.
Houtkop is offline   Reply With Quote Top
Old 03-05-2016, 07:50 AM   #3 (permalink)
jttheclockman's Avatar
Photos: 83
Default
First of all welcome to the site. Glad you found us. The most complete pen turning site in the world. On occasion we go astray and show many other talents that the members have so we are an all around group.
Your question is one that gets ask many times. I always respond to it the same way. Skip the sanding. Learn how to use a skew. You will thank yourself many times over. A pen is an object where you can do this so easily. It is small and it is round. Unlike a bowl or platter or even a turned box where you probably will need to seal the wood as you sand. With a pen, ask yourself why do I need to sand in the first place?? Is it because the surface is too rough or there are high spots that need to be knocked down. If that is the case then you need to learn to sharpen your tools and learn to use them better.
If you are going to put a surface finish on a pen such as CA, poly, or laquer of some sort you do not need to go past 400 grit of sanding. It will do nothing more. You can easily achieve that and more with the use of a well sharpened skew.. That is my recomendation. I do have a little experience in this area as I show you a couple examples of pens I made and not one piece of sandpaper touched them.
The first pen is Gabon ebony and Holy with a CA finish and the second is Bloodwood and maple with a CA finish. All woods would be prone to cross contamination if sanded. Yes I could have sealed with thin CA but to me a waste of time and effort. That is my opinion. Good luck and happy turning.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Advertisement
Old 03-05-2016, 10:21 AM   #4 (permalink)
Photos: 0
Default
Thanks for the input. I have a long way to go to get comfortable with a skew, and, I admit, my sharpening skills yield results that are less than satisfying. Time to "tool up", I guess. I appreciate the advice. I think it was Abraham Lincoln that said, "If I had 8 hours to chop down a tree, I'd spend 6 sharpening my ax".
Related Content
Reply
Bookmarks
Tags
finish , sanding dust , segmented wood
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
