Sealing Wood Blank Ends after turning - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 11-09-2017, 08:55 AM   #1 (permalink)
MRDucks2's Avatar
Photos: 0
Default Sealing Wood Blank Ends after turning
Now achieving a finish I am happy with. However, noticed that an American Patriot made with Curupay wood that cracked and fell out of my truck and lay in the grass over night (yeah, yeah, I know) had the CA finish begin to separate at the cracks (expected) but also to some extent at the ends next to the metal parts.
I ensure I get good coverage to the ends, but often need to sand the excess build-up back for a good fit. Obviously I am exposing wood in the process. Do you seal or otherwise treat the ends of the turned blanks before assembly to help prevent this?
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 11-09-2017, 09:16 AM   #2 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Thanks for reminding me Mike! I used to put a drop of thin CA on each end of wood blanks AFTER trimming them down to the tube. The wood soaked it right up. After turning the barrels, I would stand them up on a piece of 320 and lightly sand in a circle. I'm sure I learned this from someone else here on the forum about 9 years ago. Sometime ago when I took a break, I forgot that step when I went back to turning.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Old 11-09-2017, 09:21 AM   #3 (permalink)
mark james's Avatar
Photos: 419
Default
For burls and segmented blanks that I am worried about, I usually coat the inside of the drilled blank with thin CA, then redrill if the tube will not go in easily. I also glue in my tubes with 2 part epoxy. The thought is to stabilize the wood that is closest to the tube, not just the outside edge. Just my method.
And, I use a Polyurethane finish, not CA. CA is beautiful, but unforgiving with moisture expansion/contraction of wood blanks, or drops. I believe Poly has a bit of flex.
And as Chuck mentioned - yes, don't forget the ends.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is online now   Reply With Quote Top
Advertisement
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
