sanding sealer
pyurgal
Highlands Ranch, Colorado
I just tried it for the first time with a pen that I made the other day. The wood I used was Turkish walnut. I put a coat of sanding sealer on it and let it dry for about 1 hour and then put on two coats of woodturners finish on it. Then a couple coats of Ren wax. Overall the finish looks pretty good.
Paul
nativewooder
Fort Pierce, Fl 34982
When I have a client who doesn't like the feel of plastic, I will use three or four coats of sanding sealer, sanding between coats with progressively finer sandpaper before polishing.
plantman
Green Bay, Wi
:rolleyes::rolleyes: I think the reason people, including myself, sometimes use sanding sealers is because it fills viods in open grain woods and it much easier to sand then any finish that hardens. It also dries clear and brings out the beauty of the wood. If you use a water base sealer such as Hydrocoat you can sand or add another coat to it in 1/4 of an hour or less. Apply enough coats to bring up an even surface, sand, and finish with CA or whatever you use. Jim S
Wildman
Jacksonville, NC, USA.
Sanding sealer not always necessary, always optional! Sanding sealer's primary use is level surface of wood and speed up surface build of final film finish.
Contrary to what manufacturers tell you sanding sealer poor wood grain-pore filler. Just use any film finish for that purpose. Can thin any film finish to act as sanding sealer commonly called a wash coat to serve same purpose.
On porous or open grain wood better to use several thin coats of finish, allow each coat to dry completely. Do not forget dry time between coats not the same as final cure time for a finish. If try to rush things going to end up with gummy finish.
Sanding sealer not a final finish, dries too soft.
Brooks803
Aiken, South Carolina
For me after final sanding I'll wipe with DNA to clean the blank. Then I'll apply a coat of mylands sanding sealer. Shortly after that I apply my CA finish. Has worked great for me.
KenV
Juneau, Alaska.
Every one does --- because that is what the first coat does!
I use thin CA as a sanding sealer on some woods.
I use lacquer in some cases, and if I am concerned about contamination with sanding, general finishes prroduct Enduro Sanding Sealer works quite well --- followed by the general finishes acrylic top coats such as wood turners finish.
carpblaster
Shelby,Alabama
I have been using it from the start of my pen turning and some bowls,It may or may not make a difference but i will always use it to help fill the tiny holes or whatever
carpblaster
Wildman
Sanding sealer for used when lacquer going to be final finish. Levels wood surface speeds up finish film build. Not meant to be a pore or grain filler.
Wash coat nothing more than thinned shellac, varnish or poly levels wood surface and speeds up film finish build. Not meant to be a pore or grain filler.
Using a film finish on porous, open grain, or closed grain hard wood will build film finish faster. Must lightly sand between coats of vanish and poly.
Wood conditioner can buy commercial product or use shellac for softwoods to prevent blotching of stain or final finish.
Wood fillers, not something want to use on pens.
Sealers and Pore Fillers | Articles | Woodworkers Journal
If going to use CA as final film finish, wasting time with sanding sealer, wash coat or wood filler.
