endacoz
I have been using doctors woodshop walnut sanding / finishing oil and then pens plus and then his doctors woodshop walnut oil microcrystal paste wax. I cleaned my shop this past weekend and for some reason cannot find my doctors woodshop walnut sanding oil / finishing oil. I sanded with this then after sanding would put this on walnut oil and heated it up on the lathe to "seal the wood" like the Doctor says in his YouTube videos.
ic Rockler has Mahoney's utility finish heat treated filtered walnut oil. Does anyone know if this is the same product? Can I use it under the Pens plus? Can I sand with it?
Any of you sand with this type of oil before putting CA on? Or would the oil mess up the CA? I like wet sanding my wood for dust sake.
