Which requires the least sanding? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 04-28-2009, 08:20 PM   #1 (permalink)
Photos: 0
Default Which requires the least sanding?
On a spindle type turning such as a pen blank, which would leave the blank the smoothest thus allowing the pre-finish sanding to start at a higher grit, a shear scraper or skew chisel?
I read an article on the internet recently about shear scraping which indicated that a shear scraper left the wood to about the equivalent of having been sanded to 320 grit compared to a skew chisel that left the wood at about 180 grit. I thought I would pose this question to you guys to see what you thought since I have never tried shear scraping.
Thanks,
David
dabeeler is offline   Reply With Quote Top
Old 04-28-2009, 08:23 PM   #2 (permalink)
hunter-27's Avatar
Photos: 4
Default
I use a skew and typically start sanding at 320-400.
__________________
I can turn fine wood into sawdust better than most!!!!!!!
hunter-27 is offline   Reply With Quote Top
Old 04-28-2009, 08:29 PM   #3 (permalink)
Russianwolf's Avatar
Photos: 1
Default
a very sharp skew,used properly will give much better cuts without tear-out. depending on the grain, the scrapper may cause tear-out.
__________________
Mike
Martinsburg WV
I have left the IAP. If you wish to contact, use the email a member feature. I don't log in to see PMs any longer.
Russianwolf is offline   Reply With Quote Top
Advertisement
Old 04-28-2009, 09:08 PM   #4 (permalink)
Photos: 0
Default
I also normally start my sanding at 320 after finishing with the skew. The article I read talked about shear scraping producing very light wispy shavings with no tear out unlike a normal scraper. Just got me to thinking, which is sometimes dangerous.
Old 04-28-2009, 09:15 PM   #5 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Due to the fact that I had solder mixed in as part of the wood's design, I had to turn the pen "30 pieces of silver" to size and apply finish without ever sanding the wood.
I used a very very sharp scraper and it turned down to what I would say was at least equivalent to 600 sandpaper grit.
I have made about 15 and they all turned out fine without any sanding to the wood.
http://www.penturners.org/photos/ima..._of_Silver.jpg
This also works with segments with light woods and dark woods. No secrets to it other than a sharp sharp skew or scraper and a little experience.
Personally, I am not good with a skew and can get finer finishes with my own scraper than I can with the skew. If I were more experienced with the skew, I feel it could do even better.
Having said that, I will disagree considerably with the statement that shear scraping leaves it at about 320. That it is a totally subjective statement. 1. All things being equal - Soft woods look rougher than harder woods, 2. grain direction and orientation will affect it; 3. Sharpness of the scraper will affect it; 4. experience and touch will affect the degree of smoothness; 5. and so will the speed of the lathe - especially on the shear scraper.
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 04-28-2009, 09:44 PM   #6 (permalink)
jttheclockman's Avatar
Photos: 104
Default
I always finish my blank with the skew in the scraper position and I start right to the micro mesh on acrylic. On wood I might hit it with 800 grit.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 04-29-2009, 08:26 AM   #7 (permalink)
Photos: 1
Default
What is always left out of any comparison of tool finishes is the wood. All things being equal, shear scraping can leave a better surface finish than a skew chisel on the very hard dense and close grained species, but it can't come anywhere close on everything else.
If you really want to see the extreme differences, try using a both scraper and skew on Cocobolo, Blackwood, or Desert Ironwood. You will find that the scraper might be the better tool for these very hard species. At the opposite extreme, the scraper will be a disaster on a soft wood like Douglas Fir or Pine, while a sharp skew can leave a smooth clean cut and polished surface that doesn't need sanding.
__________________
Russ Fairfield
Post Falls, Idaho
Visit my Website for instructions on making a pen
http://www.woodturner-russ.com/Pen10.html
RussFairfield is offline   Reply With Quote Top
Old 04-29-2009, 08:37 AM   #8 (permalink)
GoodTurns's Avatar
Photos: 27
Default
Quote:
exactly my method.... If I hit the wood with 400, I can see that it gets rougher than the final cut was...
__________________
Jon Piper - Beautiful Downtown Bowie, MD
You can take this as far as you believe!
www.eaglepens.com
GoodTurns is offline   Reply With Quote Top
Old 04-29-2009, 09:32 AM   #9 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Thanks Russ for this information. I am not proficient with the skew and could not make statements on that basis. I do know what you wrote about the shear scraper - on soft woods, it is a disaster! On hard woods it is super!
I am saving a link to this thread for reference simply because of your input. Thanks again!
__________________
Hank Lee
Old 04-29-2009, 07:23 PM   #10 (permalink)
Photos: 0
Default
Interesting discussion, thanks for the input guys. Am I correct that "shear Scraping" is a
different animal from normal scraping where the scraper is flat on the tool rest even though it is a burr doing the cutting either way?
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
