Removing Silicone Lubricants - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to!
Old 03-04-2008, 05:43 PM   #1 (permalink)
Randy_'s Avatar
Photos: 34
Default Removing Silicone Lubricants
One of my questions in this year's Birthday Bash had to do with removing silicone lubricants. The primary reason for the question was to help folks who might get their blanks contaminated and have problems with the finishing process. Here is the question as it was posed in the contest.
[font=Arial]"Most of us have some sort of silicone based lubricant in our shop and it is a wonderful material. Unfortunately, it can be a major annoyance when it gets somewhere it is not supposed to be. If you have some on your hands and transfer it to a pen blank, you can forget about a finish sticking the blank. Soap and water don’t do very much for clean up nor do most of the commonly used solvents. What is the best material to use to remove silicone lubricants?"[/font=Arial]
I received a wonderful selection of responses. Some from folks who had actually tried to clean up a mess, some from folks who had just read about a solution and were passing it along, some from folks who apparently misread the question, and some just plain guesses.
Many of these suggestions I had never seen posted before and thought others at IAP might profit from seeing so I am posting them at the end of this message. The answers will be posted will understand why after you have read the suggestions.
One thing I learned from the Trivia Contest is that it is very difficult to write a good.....unambiguous.....question. "What is the best material to use to remove silicone lubricants?" The answer to this question is quite different depending upon whether you are trying to clean up a silicone lubricant from the impervious bed of your table saw or the very porous surface of a rare wooden pen blank. And there would be different solutions depending upon whether you were dealing with a finished vs. an unfinished wood, a plastic or some sort vs. a metal.
I'm going to start another thread shortly so we can delve into more detail and look at the specifics of dealing with differing materials. In the meantime, here are the responses to the trivia question.
denatured alcohol
Silicone thermosets, so there is really not much that will "dissolve" it. Naptha, rubbing alcohol and mineral spirits are often used in clean up, but present their own problems. Acetone is said to work, but I've not tried it. Silicone-Be-Gone (by DAP) works fairly well but takes a long, long time. Oh! And cleaning vinegar will work…not the stuff you put on salad, but the cleaning product which is a much higher concentration of acid (generally in excess of 7%).
Rubbing alcohol
Use 99% isopropyl alcohol
To remove silicones from a wood surface, use a cloth dampened with
turpentine and sprinkled with powdered laundry detergent. Rub the
surface of the wood in the direction of the grain to wash the finish.
Change cloths frequently to prevent the dirt and silicones from being
redeposited on the finish.
Randy we have the exact same problem in rodbuilding, the strongest chemical for removing silicone is acetone but even that tends to dilute and simply spread out the problem the only sure way of removing it is sanding and getting a water break free surface to work with.
Hmmm, interesting. I've seen several suggestions on how to remove silicone oil (from gasoline to ammonia), but was not aware of consensus on which was "best". The most popular material seems to be a mix of turpentine and powdered laundry detergent (ammonized detergent). If there's something better, I'd like to know.
My guess is 70% ISO
Nail polish remover
Mineral spirits
rubbing alcohol
There are special products on the market that 'digest' silicone, such as the one below. However, for something as small as a pen one of the above will work. Dicone NC9 is a specially formulated silicone "digestant", for removing silicone-based sealants and adhesives, cured silicone elastomers and silicone water repellent over spray.
Okay I may get myself in trouble here but I found two things that will
remove silicone based lubricants (one I've tried, one I haven't). The one I've tried is called Orange-Sol (although there are probably other brands out there). The other one I haven't tried (and I suppose a little more personal) is sex toy cleaners (I could say more but I'd most likely get myself in trouble.)
Any orange citrus cleaner should work or just orange juice if thats all you have.
Drycleaning Fluid
Sulfuric acid
Naptha can help with Silicone residue.
Isopropyl Alcohol
While many solvents abound...
Orange Glo (citrus based cleaning solvent)
Pre-Kleano (Automotive product)
PST Silicone Grease Remover (PolySi Technologies)
Denatured Alcohol seems to be the best option for removing silicone lubricant, rubbing alcohol would probably do just as well.
The best I've found to clean off silicone lubricants is formula 409.
We used naptha in the automotive paint industry to remove silicone contamination, but for pens I’ve had pretty good luck with wet sanding followed by a few applications of acetone.
I've been told to steal the rubbing alcohol from the medicine cabinet to cleanup silicone.
iso propyl alcohol
Randy I guess denatured alchohol.
I'm going to say... Rubbing Alcohol.
my guess would be acetone.
The best way to remove silicone lubricants spilled in the shop is with an inert non-combustible material.
That being said … the most commonly used material by most at IAP will likely be SAWDUST.
It is not however, the safest method. Kitty litter would be a safer alternative given that it is generally not a combustible material. (I’m sure some idiot somewhere is making some that is.)
Denatured alcohol.
mineral spirits/paint thinner?
6:1 mix of iso alcohol and ammonia
Straight from the horse’s mouth: or in this case the manufactures web page.
Remove with soap & water, CRC HydroForce® All Purpose, etc. and elbow power (scrubbing).
That is an easy one, rubbing alcohol !
Denatured Alcohol.,
I haven’t a clue really, but I’ll guess sandpaper?
Rubbing alcohol ??????
Get the power of Windows + Web with the new Windows Live. Get it now!
The best chemical I know of to remove silicone lubricants is
methylsiloxane. Unless the silicone is in the wood, and then your best
bet is sandpaper! :)
DNA (denatured alcohol), I believe is effective in cleaning silicone.
I don't think that soap, water or even a solvent will remove the silicone - the best way would be to sand it off....
To remove silicone based lubricants you can use a spray bottle with 70% ISO alchohol.
Also stated elsewhere is says you can use a cloth wet with turpentine and sprinkle with powdered heavy laundry detergent.
Randy_ is offline   Reply With Quote Top
Old 03-07-2008, 12:41 PM   #2 (permalink)
Photos: 27
The best way to fully remove silicone from wood is one of the oldest forms of sterilizing....FIRE. It probably would not be advisable in a shop full of sawdust and shavings though. And it may cause dicoloring of the pen blank. This gives me an idea though, so off to the shop to try it. I will post a picture of my results.
Johnnie Jarheaded
If you don't like what I say or do, don't look or listen.
You always have an option.
RIP 4/8/65 - 10/29/08
Jarheaded is offline   Reply With Quote Top
Old 03-07-2008, 02:12 PM   #3 (permalink)
Photos: 0
Johnnie, you might want to dail 911 first to get started on there way. :D:D
loglugger is offline   Reply With Quote Top
Old 03-07-2008, 02:42 PM   #4 (permalink)
Photos: 0
Johnnie's time in the military seems to have given him a very distorted perception of what is considered 'safe'.[:o)][:o)][:o)] This is in reference to some of the other things he says he has done or tryed to do.
Paul Sherman
Jonesboro, AR
Anyone who has never made a mistake has never tried anything new.
-- Albert Einstein
pssherman is offline   Reply With Quote Top
Old 03-14-2008, 07:37 AM   #5 (permalink)
redfishsc's Avatar
Photos: 42
Jarheaded is 100% RIGHT!!!
My training is in professional cabinetry/furniture finishing (which is why I spray my pens with stuff most people haven't heard of and can't find...:D)
Silicone prevents proper adhesion of the finish (basically every film finish) to the wood, and on tables/cabinets it is called "fish eye" and looks like a brain surface after the finish is sprayed.
Here are some fact about silicone contamination that EVERY woodworker needs to be aware of.
1) So far as I've researched, which is quite extensively, silicone contamination CANNOT be removed. It's like removing dried wood stain from carpet (don't ask me about that one[B)]). If you don't believe me, read the story below.
2) Silicone contamination is best avoided by NEVER purchasing and using anything with silicone in your shop. Toss them out. (BTW, one scapegoat is WD40-- is has NO silicone but is accused of it all the time-- it is safe).
3) Furniture polish has silicone, usually. Just know that if you go to refinish something, you may deal with silicone contamination (which, when finish is sprayed onto it, causes "fish eyes"-- a brain-like texture).
4) Learn from this HORRIBLE experience I had. I had a co-worker, the office clerk, commission me to refinish her family heirloom oak kitchen table (100+ years old). It had been cleaned with furniture polish, and even with the thick, thick coats of old varnish on it, the silicone was WAY DOWN into the wood grain. I had to break all the glue joints in the table top (which were breaking from age), cut fresh glue joints, glue the table back together, re-round the table with a router, and then, GET THIS: PLANE OFF MORE THAN 1/16" OF MATERIAL from the surface of the table to flatten it out. IT STILL HAD SILICONE "FISH EYE" CONTAMINATION. If a planer won't remove the contamination, NO solvent will. I used the trick below to get it right, and the table turned out fabulous, but at twice the man-hours I had hoped for.
There is ONE, and only ONE way that I have found to combat silicone contamination (notice I did NOT say "remove"). You must buy "fish eye eliminator" from a specialty finish store (sometimes Sherwin Williams has it). It isn't cheap ($40 a quart usually) and you only need to add a few drops to a quart of finish. All it does is allow the finish to lay flat, and it has to be experimented with b/c the level of contamination varies from piece to piece. I usually wind up spraying 2X the number of coats I would normally spray, with heavy sanding in between, as I sneak up on the right amount of fish-eye killer. BTW, you don't want to just dump in a ton of fish-eye killer b/c it can make the finish brittle and cloudy if you use too much. You have to sneak up on it per the Mfr's instructions (if they give you any).
So, all this to say, silicone=[}:)]. Best keep it OUT of your shop I don't care how useful it is.:(
Wake Forest, NC
"Jesus did not come to make bad people good. He came to make dead people live." Ravi Zacharias
redfishsc is offline   Reply With Quote Top
Related Content
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread:
Posted By For Type Date
Silicone & Pledge furniture polish - by cr1 @ ~ woodworking community This thread Refback 01-28-2012 04:54 PM
Novus Plastic Polish Advisory - Topic This thread Refback 01-19-2012 05:06 PM
Need help removing silicone grease from pen feed - The Fountain Pen Network Post #0 Refback 01-10-2012 05:50 AM
Content Copyright © 2003-2018 by, LLC; All Rights Reserved
