Joe Burns
Have a question on finishing out clear polyester resin. I am presently turning one of the great polyester resin braid blanks from KnB. I have the blank turned down almost to the bushings. To the point that if it was wood I would start sanding and the finishing process.
This is the first time turning one of these blanks. What would be the best process or steps to finish the blank out. I have all new fresh micromesh to 12000. Hut's plastic polish and a two wheel buffing system for the lathe.
Not sure if I should dry sand with 220 or 400 first before moving to micromesh. I also have Abralom 500,1000,2000, and 4000 pads.
Any turners out there that have turned clear polyester resin before? If so what process or steps do you use?
Joe
Joe
