Polishing Papers
08K.80
Plenty of views and zero replies. I'm guessing it hasn't been used by anyone? I've found it at several outlets and the claim is mirror shine on plastics and metals and no dark residue on bone, use it wet or dry. It's relatively inexpensive, so I think it will go on my long list of things to try.
08K.80
Sorry, the link works for me. Google 3M polishing papers.:wink:
Looks to me like an alternative to MicroMesh.
Chris, it's always good to have an alternative.:wink:
Maybe someone has used it and can confirm likeness.
TwoCatsPens
Nashville TN. Area
How does 30, 15, 9 and 3 microns relate to the grades in MM? Higher, lower, same range? The thing I like about MM is that with the 9 pad set I feel like I'm never making a big jump.
Steve
08K.80
Steve
One of the sites gave a grit comparison. There wasn't a big jump between them. It probably states on the 3M website.
They have a similar product also. I think it had the same claims and they both mention glass polishing.
its_virgil
Wichita Falls, TX, USA.
Micron Grades (µ).......Approximate sandpaper-grit equivalent
80µ...................................180
60µ...................................220
40µ...................................320
30µ...................................400
15µ...................................600
9µ.....................................1200
2µ.....................................6000
1µ.................................….8000
MM microns
1500 30
1800 18
2400 15
3200 12
3600 9
4000 5
6000 4
8000 3
12000 -
08K.80
I think you're correct Don. On StewMac's site, it lists them as this...
6040
Green, 30 micron/400 grit, per sheet Yes
$2.36
6041
Gray, 15 micron/600 grit, per sheet Yes
$2.36
6042
Blue, 9 micron/1200 grit, per sheet Yes
$2.36
6043
Pink, 3 micron/4000 grit, per sheet Yes
$2.36
6044
Aqua, 2 micron/6000 grit, per sheet Yes
$2.36
6045
White, 1 micron/8000 grit, per sheet
its_virgil
I actually purchased two sets of the larger sheets from The Sanding Glove at the symposium here in Texas back in August. I have been using it wet on my snake skin pens and like the results. I need to do some comparisons to see if there is any real difference.
Do a good turn daily!
Don
