plastic polish - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Finishing
  Forgot Password
Finishing It ain't a pen till it's FINISHED!
Welcome to penturners.org!
Reply
Old 03-14-2010, 09:19 PM   #1 (permalink)
Photos: 5
Default plastic polish
three questions on finishing....
1. What is everyone's favorite plastic polish?
and
2. When do you use it?
(after 12000 MM as a last step, or after 6000 MM then buff etc....)
3. What do you apply it with/buff it with?
barrysj is offline   Reply With Quote Top
Old 03-14-2010, 09:23 PM   #2 (permalink)
hunter-27's Avatar
Photos: 4
Default
Brasso, after the micromesh series, buff it out with soft cloth.
__________________
I can turn fine wood into sawdust better than most!!!!!!!
hunter-27 is offline   Reply With Quote Top
Old 03-14-2010, 10:11 PM   #3 (permalink)
Photos: 26
Default
In order: Sand to 600, Brasso, Dolphin Skin CP, then Huts Plastic Polish, then a coat of Renaissance Wax.
Application is with Paper towels, Ren wax with fingers.
__________________
I'm an enigma wrapped in a slab of bacon.
Glass Scratcher is offline   Reply With Quote Top
Advertisement
Old 03-14-2010, 10:22 PM   #4 (permalink)
Photos: 25
Default
what the heck is dolphin skin cp?
__________________
-Dan Horowitz
witz1976 is offline   Reply With Quote Top
Old 03-14-2010, 10:25 PM   #5 (permalink)
Photos: 0
Default
I use Meguiars PlastX (for cars) after 12000 MM, applied with a micro-fiber cloth. Apply end to end with the lathe off, and rub it in until the blank shines. Then a second application with the lathe on. Again, rub it until it shines.
Tom
TomS is offline   Reply With Quote Top
Old 03-14-2010, 10:32 PM   #6 (permalink)
JimB's Avatar
Photos: 11
Default
12,000MM, then Huts Plastic Polish using a soft cloth. Sometimes some wax.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 03-14-2010, 10:32 PM   #7 (permalink)
Moosewatcher's Avatar
Photos: 10
Default
I use One Step although I used to use auto polish and I'm not sure if I can see a difference.
I use the colored plastic pads on acrylic and CA. Stop at about 2400 (the purple one). On CA I use only the orange and purple pad, then go to the polish.
Use a soft paper towel, like Bounty or Members Mark from Sam's Club.
Ken
Moosewatcher is offline   Reply With Quote Top
Old 03-14-2010, 10:36 PM   #8 (permalink)
David Keller's Avatar
Photos: 0
Default
I use the stuff from Arizona Silhouette, but I can't remember what it's called. I use BLO and CA then wet sand 600 grit, then wet MM through 1200, then the plastic polish with the lathe on for a while then with the lathe off longitudinally.
David Keller is offline   Reply With Quote Top
Old 03-15-2010, 12:59 AM   #9 (permalink)
Photos: 26
Default
Quote:
You use BLO on plastics?
__________________
Old 03-15-2010, 01:06 AM   #10 (permalink)
Photos: 26
Default
Quote:
It is a ultrafine abrasive Cutting Polish (CP), used in the surfboard industry. I get it by the quart (under $20) from the surfboard supply warehouse. It makes a nice intermediary step between Brasso and Huts. It reminds me of the optical grade cerium oxide, which is in the .2-.3micron range.
It makes the final pass with the Huts really pop.
__________________
Related Content
Reply
Bookmarks
Tags
ca finish , finishing , high gloss , plastic polish
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
