pen plus finsh
penmaker1967
biscoe nc
hi guys I was at woodcraft this past weekend and picked up some pen plus finsh I have never used this stuff before can anyone tell me how the best way to use this finsh. any info would be helpful
thanks
TonyL
Georgia
I really like the product and their micro wax. However, I have seen the pens that I made as gifts and it appears the finish didn't hold up on at least these two pens. They were both a CSUSA Patriot with Acacia wood. They are used everyday thought. I believe I applied at least 12 coats and then the wax. The finish lasted about a month. This is only my experience. I still like and use the product occasionally.
Dan Masshardt
Mechanicsburg, PA
hi guys I was at woodcraft this past weekend and picked up some pen plus finsh I have never used this stuff before can anyone tell me how the best way to use this finsh. any info would be helpful thanks
1. It works best on hard woods.
2. It doesn't fill gaps so make sure you start your finishing over a stable surface. I either use a coat if ca or a drop if pens plus between sanding grits.
3. Really heat it up on the last couple applications. This is important.
